Wire identification help
Old Feb 21, 2018 | 06:21 PM
qed296's Avatar
qed296
Default Wire identification help
Hoping you can help me id the wires on this sapphire 4x4 stereo plug. Starting from the left (ford logo side) if you can please.
Also the 3rd wire in from the left (brown with yellow trace) is missing from the splitter loom to the radio & cd player....is that possibly causing my issues??
Both ends of the original ford splitter loom are like this, missing the brown wire with yellow trace.
As always I'm sure someone on here can help me out.
Old Feb 21, 2018 | 06:48 PM
Caddyshack's Avatar
Caddyshack
I gues that might be dim from instruments to dull the lights screen when lights on. Try putting a probe in and see if it goes live with lights on.
Old Feb 21, 2018 | 07:28 PM
qed296's Avatar
qed296
Good point....never crossed my mind to try that.
Old Feb 22, 2018 | 06:27 PM
4x4kiwi's Avatar
4x4kiwi
Please find attached pdf of the wiring diagram for the stereo. The CD player is shown below where it says equalizer and definitely shows the brown / yellow (BR-GE) wire in place.
Hope this helps
David
File Type: pdf
Old Feb 22, 2018 | 07:10 PM
4x4kiwi's Avatar
4x4kiwi
A couple of other diagrams you may need. The wire in question goes to the anti theft module (alarm). You will see the radio in the bottom left corner of the alarm drawing with the same wire number.
David
File Type: pdf
File Type: pdf
Old Feb 22, 2018 | 07:25 PM
4x4kiwi's Avatar
4x4kiwi
By the way, I believe it is the small Grey with yellow trace wire next to it that is for the lighting (from fuse 7) For info: BL - Blue, BR - Brown, GE - Yellow, GR - Grey, GN - Green, RS - Pink, RT - Red, SW - Black, VI - violet, WS - White. Its a German thing I believe.
David
robbo9006
Nov 26, 2011 04:17 AM
RickyLee53
Mar 1, 2009 07:33 PM
BIGMATT1
Mar 14, 2008 06:52 PM
Lambchop
Feb 4, 2008 04:51 PM
abdr500
37
Mar 1, 2006 05:44 PM
