Tech help!-what happens if you dont put wire in wire rung...
...block when you put an engine together?
Basically this wasnt done when my engine went back together
The bottom end was bought 2nd hand and had done 1600miles before the car was rear ended. It had had a full rebuild and should be sweet. Now when in my car and engine is started theres a horrible tappety/chappy noise coming from the engine. I'd had a few people have a listen and they werent sure if it was bottom end or top.
Last night i got the car recovered to a garage where 2 guys are gonna fix the car. Having started it and listened they didnt think it was a bottom end issue. They felt round the back of the block and said that if there was something not right they'd feel it on the block? They were thinking its summat in the middle. So then i remembered about the lack of wire in the wire rings and they wonder if that could be causing the problem. Does anyone have experience of not using the wire? Can it cause a problem with the seal round the bore?
chop
chop
if the other cylinders have the wire in them and the middel ones dont they wount seal 100% but if all the wires from the block was removed and the gasket laid on top it can still bite into the grove with out the wire ..
so is ither with the wire or with out not pix and mix
Originally Posted by Lambchop
there is no wire at all...
ither way the sound my not be relaed to the gaske it may be a littel end noise fron the con rod that make a rattel sound that sounds like its coming from the head
someone else did mention little ends.
head comes off tonight anyway for a look.
thats fine then i have none people to do this with good results the fireing ring on the head gasket will still crush the same but were the grove is cut it will simply indent it self there and lock it self when you take it of you will kind of see
Originally Posted by cossie4i
Mine does not have the wire in and runs fine
Peaks at 1.8bar as well.
Steve.
Steve.
why didnt you put wire in?
he said it as if he meant to leave it out hence me asking why that choice
Super Moderator
Originally Posted by Chip-3Door
Simple maybe, but surely thats going to have your piston tops protruding another 20thou unless you start skimming them as well, which will then move the top ring further up, so you still have potential problems.
EDITED: Damn tooooo slow
Just posted on your other thread Chops
When i had a listen it deffo sounded like a small end. Couldnt pin point it as the tapping noise was from the centre of the engine.
Std or Grp-A gasket will be fine without rings in the block but if you are going for a multi layer WRC jobbie then do as above
It Wasnt Me!
Who put it together chop? has it done any miles?
Hard to tell what it is without hearing it, sure all will be revealed when its taken apart! atleast for the price of some gaskets and head bolts you'll know for certain!
Originally Posted by Andy_R
Finger crossed for you, good luck with getting it up and running quick mate, its been out of action for to long.
ita well under way now and many Ł's spent already
dann
now i know what you're on abaout, why do you think it's cause a melted piston?
dave
bought 2nd hand after 1600miles. in bits now and will be built soon. fingers crossed
she's getting prepped for an mot too
Chop.....I hope your missus dont see this thread.....could be a recipe for divorce.....hand her my number if this is the case!!!
Hope you get it sorted though mate......I dont actually believe this car exists yet!!
i do actually worry when i post shit on here
maybe one day i can treat you to a trip to germany and back in 1 piece in the same vehicle
dann
dave
TT T38 Power
Steve.
Steve.
Done about 25000 miles like it as well
Steve.
dann
dave
we're talking 2 DIFFERENT engines mate.
"original" engine in the car melted a piston. NONE of that is currently in the car.
the "new" bottom end is the only 1 with wire ringing. We put it together with a "new" head and it makes a horrible noise. Its only run for 10mins total maybe to check the problem. the sump is off it and there are light marks on the shells. engine out and head off tonight
Originally Posted by KSA-Cossie
Has it actually been on the road in your possesion chop ??
bought in aug 05
went on fire 2 days later
got it back 3 months later after shed loads new bits, then found fucked headgasket when it was run immediately after the fix.
ran ok for couple months
developed missfire which wasnt cured until maybe may 06.
melted piston aug 06
changed engine jun 07 but car refused the transplant
jan 08 the ball is rolling again
it WILL come back strong!
kyle_st200
Ford Focus Diesel
21-08-2015 09:28 PM
muz
16-08-2015 12:57 PM
