clocks removal
Old Feb 14, 2018 | 09:38 PM
krolly's Avatar
krolly
Default clocks removal
as title reply I want to take the clocks out and change the sold from the white Lockwood ones to some black ones. problem is I haven't got a clue where to start, any advice on how to remove the clocks and then change the dials would be great
Old Feb 15, 2018 | 05:13 AM
haz87's Avatar
haz87
Top of my head
- Remove the upper steering cowl (2 screws).
- Remove the clocks fascia (plastic cover that surrounds the read heated screen switch etc) (2 screws at top + disconnect wiring from the back of the switches etc)
- 4 screws then hold on the actual clocks unit, remove these and slide the unit forward
-Disconnect 2x wiring connectors + speedo cable allowing you to remove the unit in full
Then to open up the clock unit:
-About 6/8 screws in the back of the unit round the edge, undo these, that'll seperate the unit in 2
-Carefully prise off the needles making a note of exactly where they are sitting
-You can then get at the dials themselves
Thats all off memory but dont think i've missed anything major
Old Feb 15, 2018 | 11:50 AM
bassboy's Avatar
bassboy
Originally Posted by haz87
Top of my head
That covers pretty much whats involved...be prepared to swear some while trying to disconnect the speedo cable!
Old Feb 15, 2018 | 05:18 PM
speedo cable is easy ,feel for the ribbed section of the white connector on the end of the cable at the back of the clocks, then push this across and pull it off (the connector is round and you want to push it across the hole if this makes sense
Old Feb 16, 2018 | 10:28 PM
krolly's Avatar
krolly
all sorted now guys thanks
Old Feb 18, 2018 | 08:05 PM
Rsmat's Avatar
Rsmat
Do you have a link to buy them mate
Old Feb 21, 2018 | 03:23 PM
bassboy's Avatar
bassboy
How good do they light up?
Old Feb 21, 2018 | 05:23 PM
slammedorion's Avatar
slammedorion
If that’s the Lockwood black dials, they look good
Old Feb 23, 2018 | 02:23 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
That right-hand indicator symbol lines up really badly, no?
Old Feb 23, 2018 | 02:28 PM
Rsmat's Avatar
Rsmat
Only on the white set ..my white set was miss printed there as well ..white shite glad I removed .
Old Feb 24, 2018 | 03:39 AM
GVK.'s Avatar
GVK.
Should the temp. gauge needle be like that at rest, would've thought it should be closer to the gauge?
Old Feb 24, 2018 | 10:53 AM
Rsmat's Avatar
Rsmat
Guage as either shook a 7 or the sender has ..or either connection / bad earth mate.
16vzetec
Nov 20, 2008 07:33 PM
tore_tj
Ford Escort RS Cosworth
14
Oct 22, 2008 01:35 PM
BeanFiesta
Feb 15, 2006 04:32 PM
Rick
11
Jan 22, 2006 10:47 PM
