just a quicky
Old Feb 4, 2018 | 04:43 PM
Adder's Avatar
Adder
Default just a quicky
Hello folks,
Ive ordered an Omex 600 and im trying to get familar with the wiring. its a zetec turbo and i was wondering whitch is the temp sender and whitch is the temp gauge.
many thanks
adder
Old Feb 4, 2018 | 05:18 PM
Caddyshack's Avatar
Caddyshack
Your post doesn't make sense? The temp gauge is in the car, the sender / sensor looks to be that white plug that has the brass sender on the end.
Old Feb 4, 2018 | 05:48 PM
Adder's Avatar
Adder
Sorry the confusion,
What I'm trying to find out is which of these sensors dose what when it comes to wiring up the ecu ? I know one will be to the temp gauge and one to the ecu ( I presume) but, what dose what in the pic ? What I'm looking for is
The one under stat ( you can just see it ) housing goes to ?
The one on top of the stat housing goes to ?
Thanks in advance
Adder
Old Feb 4, 2018 | 06:19 PM
Caddyshack's Avatar
Caddyshack
I don't think it matters as long as they both have the same values (I think some read different amounts) I would assume Ford used the same (let's say resistance) so both will read temp so use whichever you like. They are so close you can make off the loom and swap connectors if it doesn't work. I expect they are just pre and post thermostat. I wonder if the ecu might want the pre as true water temp.
Old Feb 4, 2018 | 08:25 PM
Adder's Avatar
Adder
Cheers anyway, I'm half tempted to get someone in to do in any case. I just wanted to have a bit more understanding
Thanks
SamERST
Aug 25, 2005 05:48 PM
Westy
Jun 1, 2005 07:16 PM
warleydaddy
17
Mar 12, 2005 07:48 PM
Zetec Andy
Aug 6, 2004 06:59 PM
