Standard airbox & 500 style intercooler issues
Old Feb 2, 2018 | 01:55 PM
qed296's Avatar
qed296
Default Standard airbox & 500 style intercooler issues
Just sorted all the parts and blow me it won't fit now.
seems the intercooler pipe to the turbo is to large, wrong shape....not really sure as the box won't sit down onto the inner wing as the front mount hits the pipe.
It has a XSPOWER rs500 style inter cooler with pj silicone hoses that look to be about 70mm dia.
any ideas or suggestions as to a hose that accommodates the o/e airbox.
cheers
Old Feb 2, 2018 | 05:01 PM
Caddyshack's Avatar
Caddyshack
Can you stick up a picture of the problem. People like Ggr sell custom hoses
Old Feb 2, 2018 | 05:15 PM
qed296's Avatar
qed296
Trying....photobucket seems to be struggling
any ideas on a good image hosting site plz....
Old Feb 2, 2018 | 05:19 PM
Caddyshack's Avatar
Caddyshack
You don't need a hosting site, this site does it for you, I will post up a pic of what to press.
Old Feb 2, 2018 | 05:20 PM
Caddyshack's Avatar
Caddyshack
Press the yellow icon and then browse your phone or computer.
Old Feb 2, 2018 | 05:24 PM
qed296's Avatar
qed296
Just a test pic....the washer bottle has been dropped out for a bent neck type....I'm off out the garge to get some decent pictures. Thanks for the help...pictures make things so much easier to explain
Old Feb 2, 2018 | 05:28 PM
Caddyshack's Avatar
Caddyshack
Cool, yes we will get it sorted now as loads on here will have solved the problem
Old Feb 2, 2018 | 05:31 PM
qed296's Avatar
qed296
Didn't realise till yesterday, I work in Lincoln next to Roose, there sorting me a 70mm to standard for the airbox in matt black o/e colour....hope to do them all now
Old Feb 2, 2018 | 06:03 PM
Caddyshack's Avatar
Caddyshack
Yeah, roose are great, I have them on mine
Old Feb 2, 2018 | 07:57 PM
qed296's Avatar
qed296
Hose in place
Old Feb 2, 2018 | 08:00 PM
qed296's Avatar
qed296
Hose off, intercooler end is 60mm o/d .....turbo housing is 50mm/52mm
Old Feb 2, 2018 | 08:04 PM
qed296's Avatar
qed296
Now with an original hose laid over the blue hose its clear the extra material on the bend is the problem....i have put the o/e hose onto the turbo housing and it does create exra room for the airbox to fit in....
Old Feb 2, 2018 | 08:21 PM
Caddyshack's Avatar
Caddyshack
Can you heat it up and make the bend tighter?
Old Feb 2, 2018 | 08:30 PM
qed296's Avatar
qed296
Is that possible???
I would like them all in black eventually, I'm happy to cut both up to make a template, 60mm blue end from the intercooler should sleave over the orange to make a good guide for making what' really needed.
Old Feb 2, 2018 | 09:24 PM
jason_nike's Avatar
jason_nike
I've been thinking about refitting my standard airbox too, think OEM looks better
Old Feb 2, 2018 | 10:01 PM
qed296's Avatar
qed296
Second that, my goal is to go o/e looking under the bonnet...
intercooler & radiator will be sprayed/coated black too for the o/e look.
nice colour sapph Jason.....
Old Feb 4, 2018 | 10:57 PM
1374lee's Avatar
1374lee
Yep, airbox has just been fitted back on my car,the turbo to i/cooler hose is very tight to the side of the airbox, I have a T34 turbo fitted.
Thanks. Lee.
Old Feb 5, 2018 | 05:28 AM
qed296's Avatar
qed296
What hose are you using?
The intercooler is 60mm to 50mm on the turbo (0.48)
Old Feb 5, 2018 | 05:41 PM
qed296's Avatar
qed296
A bit of an update,
After taking off the heat shield bracket and flipping it the correct way and removing the hose from the intercooler the airbox dropped straight into position.
After fighting the arch liner and using new nuts and bolts it all came together nicely.
surprisingly with the base of the airbox in place the intercooler hose went back on with no issues.
The airbox (60mm) to turbo (70mm) did need trimming about 50mm off the airbox end and 25mm off the turbo end for good fit but that's getting replaced with a Roose oe black item and now knowing the intercooler hose fits the whole lot can be done.
Question, on the amal valve there is a small hose not connected to anything.....should it be??
Is the 8mm tube off the airbox lid surposed to be connected to anything??
Old Feb 5, 2018 | 06:23 PM
bigdel's Avatar
bigdel
Dunno if it's different for your car, but on my 3dr the left hose goes to the airbox, the centre goes to the actuator and the right one goes to the compressor housing
Old Feb 5, 2018 | 06:24 PM
bigdel's Avatar
bigdel
Oh, and the water hoses are Roose OE black silicone
Old Feb 5, 2018 | 06:59 PM
qed296's Avatar
qed296
Thanks for this, just seems odd not to connect to anything.
Old Feb 5, 2018 | 08:02 PM
qed296's Avatar
qed296
Old Feb 6, 2018 | 09:03 AM
qed296's Avatar
qed296
Old Feb 6, 2018 | 04:31 PM
Jules44's Avatar
Jules44
10 Year Member
Originally Posted by qed296
Mine is exactly the same as that 1988 2wd
Old Feb 6, 2018 | 06:59 PM
qed296's Avatar
qed296
Now I'm confused, this redtop with blue slam panel looks to be plumbed in the same as mine with the coloured lines on...or are my eyes plain trick on me....Bigdels looks to be a different arrangement...
Old Feb 6, 2018 | 09:30 PM
bigdel's Avatar
bigdel
Well, im off to connect mine up properly. Thought the amal valve wasn't working so replumbed it to run direct, but it looks like the pipes were wrongly routed after all. Maybe I should have read my book...
here's your definitive answer
Old Feb 6, 2018 | 09:52 PM
qed296's Avatar
qed296
Thanks Bigdel....just stumbled across a thread from 2011 by stu@ m s developments on this subject.
quote :
C - compressor
W - wastegate
R - airbox
I also managed to find the vac pipe from the airbox that was missing on ebay tonight.
bigdel - what's the book you have there and is it still available ??
Old Feb 6, 2018 | 10:19 PM
bigdel's Avatar
bigdel
It's the Ford workshop manual for the Saff & 3dr Cosworth
Bought it years ago from my local Ford dealer. Don't think they're available there now though.
Some on EBay but they aren't cheap
http://www.ebay.co.uk/itm/183055104157
Old Feb 6, 2018 | 10:26 PM
Jules44's Avatar
Jules44
10 Year Member
You can download the manuals from here http://www.racetuners.com/julian-god...-pages/2789-2/
RSKieron
Mar 17, 2005 10:35 PM
Andy f
Dec 8, 2004 09:55 AM
sideways500
Sep 25, 2004 11:28 PM
Gavin E-Cos
65
Sep 15, 2004 01:10 PM
