Piston oil jets
Old Jan 29, 2018 | 04:43 PM
mattman1234's Avatar
mattman1234
Default Piston oil jets
I did mention this in other thread,,I'm going dry sump in my dax cosworth,think i've got all the measurements sorted,one thing has sprung to mind,,what about the piston jets,,has anyone backfed through the oilway,with a conversion plate where the oil pump used to be ??
Old Jan 29, 2018 | 04:45 PM
Caddyshack's Avatar
Caddyshack
I imagine you need to wait for Mark Shead to chime in on this.
Who is building your engine?
Old Jan 29, 2018 | 05:01 PM
mattman1234
Engine is already in car and running,the main reason i'm changing is for sump ground clearance,its about 50mm from the ground
just looking at the pic below,you can just about see it,,,and its even lower now
Old Jan 29, 2018 | 05:11 PM
Caddyshack's Avatar
Caddyshack
Ah, gotcha, I split the sump on my 7 showing off to a blonde, we yumped and there was oil everywhere
She gave it up though
Old Jan 29, 2018 | 05:17 PM
mattman1234
easy done !
Old Jan 29, 2018 | 05:18 PM
Caddyshack's Avatar
Caddyshack
Originally Posted by mattman1234
easy done !
Yes, she was
Old Jan 29, 2018 | 05:20 PM
mattman1234
Old Jan 30, 2018 | 03:01 PM
mattman1234
anyone ?
Old Jan 30, 2018 | 04:52 PM
mattman1234
here's my plan:-
Tap out the old oil feed hole hole(m16ish,or whatever the size is),from where the pump fed through,use a solder type banjo,re-configure/join/braze,the old existing oil spray bar,re fix where nesessary.Use a take off plate over the old oil filter,join both pipes together so one will be back feeding down to the jets.
now shoot me down.
Looking at an old oil pump,the jets only work on bypass,i assume this is to keep the pressure up on low rpm,but on the jets that are machined into the oilway they would be flowing all the time.just curious ,would the standard internal pump need to be uprated to compensate for low rpm.I'm not going down this route,just curious.
Old Jan 30, 2018 | 05:13 PM
lacey's Avatar
lacey
You need some kind of pressure control
You don't just want it dumping oil all the time
Old Jan 31, 2018 | 04:45 AM
nixon_2wd's Avatar
nixon_2wd
The oil jets that are machined and fitted directly to the block have springs in them to retain pressure. Dont really understand where you would feed the std pipe from?
Old Jan 31, 2018 | 03:18 PM
mattman1234
would be fed from the existing oil way where the pump would normally feed oil into the oil filter,i could fit a pressure relief valve on the pipe feeding into the adaptorplate that i am back feeding
Old Jan 31, 2018 | 03:28 PM
mattman1234
Old Jan 31, 2018 | 05:13 PM
Caddyshack's Avatar
Caddyshack
When did you last upgrade the firmware on your CAD system?
Old Jan 31, 2018 | 05:17 PM
mattman1234
its commodore vic-20 software,i was thinking of using a vicrel box to control the engine management
Old Jan 31, 2018 | 05:18 PM
Caddyshack's Avatar
Caddyshack
That brings back memories, we still have a Commodore 64 and zx spectrum in the loft.
Old Jan 31, 2018 | 06:49 PM
nixon_2wd's Avatar
nixon_2wd
That will work fine matt.
Old Feb 2, 2018 | 04:48 PM
mattman1234
Cheers nixon,,i'll get some pics up when i start
muz
Feb 10, 2009 08:36 PM
blueskies85
Dec 3, 2008 06:05 PM
turbospud1
Jun 5, 2008 12:58 PM
Shorty
28
Jan 13, 2007 06:06 PM
Martin-Hadland
32
Aug 21, 2005 06:39 PM
