Live engine monitoring options
Hi All,
What does everyone recommend nowadays? I see the secs and other options but seem hard to get and i seem to be a dumby on what is needed to acheive this so just wondering what is out there.
Its in a 4x4 L8 green ecu with a stage 1 MSD chip at the mo.
I really just want to get rid of all my gauges so things are neater and be able to use it for fault finding etc. Like the IAW software and have a little display that looks close to period correct etc.
Its not physical ECU live data though via the ones that solder to the sensor wires,
You really want one that will stream data via the serial data stream, so can give far more info and just plugs into the diagnostic port
https://www.autodynamix.co.uk/auto-d...g/dtm-monitor/
This is the one James does, hes fitting one to my mates escos looks a good bit of kit
very nice
I'm tempted,
i agree with the solder thing,,thats what put me of the secs,if you see it through the data port,then you know its a true ecu reading
just looked at his webpage,rolling road/mapping
I'm tempted,
So with the monitors that need a pectel or collins board i assume that replaces the baby board thats in the L8 as standard? Do these need any soldering or just "plug n Play"?
Where can you buy these from?
Im assuming, but will check that since i have an MSD chip that was bought back in 2011 that the comms is enabled as i read a post from 2006 that Stu said all chis from then on will have it enabled by default. This was when they started supplying the IAW software.
Also im about to install the MSD Wasted Spark kit, is there any considerations here for any of these monitoring options?
The 'boards' are misunderstood, the baby board is native in the L8, if you remove it your essentially left with an L6. The Pectel board allows decryption to run Pectel's software.
Stu is probably referring to his own chips, MSD are the sole distributor of IAW, so that would figure.
No, although as you probably are aware your ECU will need drivers installed for this.
Martin
I have contacted a couple of suppliers to get some info for what i need also but ill see who gets back to me.
Im thinking ideally id purchase the IAW software for diagnostics etc and one of the live monitoring device/screens for while im driving etc or is this over kill or redundant?
Hi All,
This does look good. I found a link to the instructions which provide better info then just randbmotorsports site. I have emailed them about the collins monitor that i found on their site but i havent heard back.
Its funny that we all love our old fashioned 3Doors, Saffs and Escos cars but want the very latest high tech monitoring systems. Its never bothered me and if I had constant monitoring of everything I would be checking it all the time and worrying if a reading was slightly out from normal and not enjoying driving it!! Good luck to those that like it but its not for me.
The good thing with monitors like the DTM is that they constantly record onto an SD card, so if anything did go wrong, or you want to have a look over the running data, you can just pull the card out and read a full data log, you dont need to constantly look at the gauges.
Ignorance is bliss if your cars running right
As said the DTM's data logging capability is decent as well.
Martin
Maybe I have been lucky but my engine does not lose oil or fluids, has no oil leaks, has had new engine, fans and fuel pump wiring looms, lots of uprated and new parts and gets serviced on a regular basis and so far despite getting thrashed its hanging together well.I never worry about something going wrong and if it does it will get sorted out.Its a car and no matter what monoriting devices you have there is no such thing as a 100% reliable car.
I have spoken to James about when the L8 support will be available and hes hoping sometime next month so thats not a long wait to see how it turns out! He says it will do the same as the IAW software aswell so this this sounds great. Im curious on the mounting for this in a sapphire dash tho.
Thanks. Lee.
Martin
Cheers Paul
I'm going till the end of the month to see how the progress on the auto dynamics one comes along and how it mounts. If that doesnt suit then ill probably buy this
http://www.cosworthenginemonitor.co.uk.
I have emailed randbmotorsport twice to get info about the ones on their site but theyve never replied so i wont be buying from them.
Raj_FRST
Jan 15, 2009 11:28 PM
RobCarden
11
Oct 16, 2005 08:57 PM
