Focus 1.6 taco limp mode when cold
Old Jan 14, 2018 | 07:21 AM
Lodgey47's Avatar
Lodgey47
Default Focus 1.6 taco limp mode when cold
Hi
Title should say tdci
I have a problem with my Focus which seems to be fairly common though mine is slightly different! The car starts fine but when I set off and rev over 2000 ish rpm when cold the engine fault light comes on then won't rev above 3000 which I guess is limp mode. If i shove my foot down harder on the throttle it will give a little splutter and the engine then stops completely but a quick off and on with the ignition and it starts again fine and isn't in limp mode but again if I give it more than around 3000 rpm the same thing happens. When warm the engine fworks as it should. Looking on here glow plugs seem to be an issue and I wondered if mine could be the same or because the engine dies completely do I have a different issue? Thanks
Old Jan 14, 2018 | 07:59 AM
oldford's Avatar
oldford
I think you have more and/or different issues than just the glow plugs.
Get the fault codes read.
Old Jan 14, 2018 | 08:53 AM
Lodgey47's Avatar
Lodgey47
No fault codes coming up tried 3 or 4 times but nothing
Old Jan 14, 2018 | 09:23 AM
oldford's Avatar
oldford
Then read the fault codes when the engine light is on.
That means do not restart the engine when the light comes on, not even when you're at the dealer, just keep it running until after the codes are read.
Old Jan 14, 2018 | 09:30 AM
Lodgey47's Avatar
Lodgey47
Done that as well tried reading codes when light is on or off when driving in limp mode or when engine stops altogether but nothing I thought something would come up and btw I'm not using some cheap eBay reader it's the local garage so a decent bit of kit. Weird��
Old Jan 14, 2018 | 10:33 AM
Lodgey47's Avatar
Lodgey47
Ive tried reading codes when engine is on or off, in limp mode or stopped by the roadside when it cuts out but nothing
Old Jan 14, 2018 | 10:51 AM
oldford's Avatar
oldford
What fault code reader are you using (make, model, etc.)?
And what's the model year of the car?
Old Jan 14, 2018 | 04:18 PM
Lodgey47's Avatar
Lodgey47
I'm not sure of the make of the diagnostics machine. Car is a 2006 model year
Leady78
Ford Focus Diesel
Oct 4, 2016 09:13 AM
Darren J Garner
Ford Focus Range
Dec 12, 2014 06:12 PM
Amo22
Dec 3, 2014 08:00 PM
Stephen Earle
Nov 9, 2014 03:59 PM
whoknows
Oct 13, 2014 12:34 AM
