Amal Valve and TPS Setup
Old Jan 13, 2018 | 05:52 PM
scrotenz's Avatar
scrotenz
Default Amal Valve and TPS Setup
Hi All,
What or how do you setup the TPS correctly? It was originally set at 0.04v and the Amal Valve would click as soon as i would accelerate. I heave had it set to 0.25v which sorted an high idle issue but then the Amal wouldnt get ground signal from the ECU. Ive since set the TPS to 0.14v as ive seen that recommended but it made no change.
This is a 4x4 Sapphire Cosworth so PF09.
The Amal valve works when i ground it directly to the body so its working.
martysmartie has advised me that an incorrectly setup TPS can have a bearing on the Amal so im looking towards that.
Any advice on this would be great.
Regards Gareth
Old Jan 13, 2018 | 07:03 PM
Caddyshack's Avatar
Caddyshack
There is a setup guide on this forum...somewhere, I am sure someone can point you to it.
Old Jan 14, 2018 | 08:27 PM
scrotenz's Avatar
scrotenz
So what conditions doe sthe ECU need to activate the Amal valve? Ive set idle while at running temp with no power draw and ISCV disconnected and all is idling fine.
Does anyone have recommendation on the voltage for the TPS or any steps i have missed?
samashbymk2
Apr 19, 2018 06:39 AM
neo
Jul 21, 2012 03:26 PM
Cilly-jey
Jan 12, 2011 07:45 PM
2wd
Sep 6, 2005 12:56 PM
Dec 17, 2003 11:06 PM
