Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
No high speed wipers
Old Jan 10, 2018 | 07:08 PM
joeleeman's Avatar
joeleeman
Default No high speed wipers
As above.
Have a mk2 focus 1.8 tdci on an 07 plate.
Wipers work on on intermittent and slow speeds. But when you turn up to maxinmum speed there is no change in speed from the position before.
Could this his be a faulty stalk of should I be looking elsewhere?
any help much appreciated
Old Jan 14, 2018 | 03:17 PM
joeleeman's Avatar
joeleeman
Just a thought as I’ve had no replies, but the car has various other electrical issues.
The heated screen doesn’t work, the light on the button doesn’t flash come on or anything, car had a brand new screen today so I can count that out.
Plus various dashboard issues. Fuel gauge doesn’t always work, temperature also, had it ‘repaired’ but it’s never quite been right.
Any it’s somehow had the wrong alternator fitted. It does charge at around 13.7 volts.
To be more specific it needs a 3 pin plug but instead has a 2 pin plug!
I’m just wondering aside from the alternator could this be a bcm issue?
burnzy
14
May 14, 2017 04:11 PM
pakososa
Ford Focus Range
Feb 19, 2012 10:00 PM
leecavturbo
309
Oct 12, 2006 02:03 PM
essexrsturbo
30
Nov 25, 2005 07:31 PM
extra14
Jun 18, 2005 01:07 PM
