Sapphire 4x4 dails/cluster differences
Old Dec 29, 2017 | 11:09 PM
qed296's Avatar
qed296
Default Sapphire 4x4 dails/cluster differences
Evening all,
I'm looking at returning my clocks/cluster back to o/e spec.
They currently have a set of white dials fitted.
Now these are 170mph dails but instead of fighting with the stick on whites I've
decided to buy another set to swap them with.
Best option I thought until my replacements arrived, now I've not taken my unit out the car yet to compare part numbers but the replacement has no rest post for the Rev counter needle...everything eveythese looks okay.
so as you do I Googled it...Some have the seat belt icon,some don't, some have the resting post,some don't.
Any input please as to what's correct for a May j reg 4x4 with a face lift dash or just the differences and are they likely to work.
Old Dec 30, 2017 | 03:54 PM
martysmartie's Avatar
martysmartie
The seat belt picture was an early MK2/2WD thing. Late 2WD onwards do not have it.
I am not sure if there were any wiring differences between 2WD and 4x4, if not it should work.
On later models the fuel gauge changed from litres to fractions IIRC.
Martin
Old Dec 30, 2017 | 06:33 PM
qed296's Avatar
qed296
Thanks Martin, so are 170 clocks an upgrade that people do from a 2wd to a 4x4?? Or are they correct and I just need some without the seat blt icon??
Old Dec 30, 2017 | 09:55 PM
martysmartie
No, all Cosworth's had 170 speedos.
Yes, 4x4 did not have that seat belt icon.
Martin
Old Dec 31, 2017 | 02:18 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the facelift dials had a different cluster body to the earlier ones too
it's like 2mm smaller as the hole it goes into is smaller, but otherwise it's the same thing
not all had the rest either
you will need the actual cosworth rev counter, with the C under the needle to read correctly, the fuel,temp gauges should be ok to swap over but then again, the temp gauge might have used a different sender, the senders have a different colour band to denote what range they do
the speed should be a direct swap over if it's the 170 one
Old Dec 31, 2017 | 02:19 PM
dojj's Avatar
dojj
also it soulnds like you've got the clocks from a mk1 or an early mk2 car rather than the later ones
does the fuel gauge have numbers on it or not?
Old Dec 31, 2017 | 02:53 PM
martysmartie
I think it's an early MK2, so should have the 'litres' fuel gauge...
Martin
Old Dec 31, 2017 | 03:35 PM
qed296's Avatar
qed296
Ok folks, So the cluster in the car looks to have had the original black decals removed and the white dials glued on in place of them as I can see and feel a sticky residue like evostick.
The replacement cluster has the "C" under the rev counter needle, the fuel gauge reads 15/30/45/60 and it's a 170mph speedo, a seat belt icon.
I've plugged it in and everything works as it should except the hazard warning light icon but the indicator icon illuminates fine.
It looks a alot better plain and o/e but I will search for a proper replacement correct to my year.
Old Dec 31, 2017 | 03:49 PM
qed296's Avatar
qed296
Old Jan 1, 2018 | 12:23 PM
martysmartie
As suspected, that's litres. It's early MK2, but that's a minor detail.
Not sure what you mean by 'hazard warning light', as there isn't one?
Martin
Old Jan 1, 2018 | 03:47 PM
qed296's Avatar
qed296
The green indicator icon....I'm sure it illuminated before when I depressed the red switch on the column top...but then again that flashes for the hazard lights....perhaps I've finally tipped over the edge...
Old Jan 1, 2018 | 07:33 PM
dojj's Avatar
dojj
when you press the hazzard light switch the red bulb lights up not the indicators
Old Jan 2, 2018 | 08:52 AM
Marc sierra's Avatar
Marc sierra
You don't need the actual cosworth rev counter, any 4 cylinder rev counter will work. The Cosworth rev counter with the 'C' just means the red line is at a different value (~6500 RPM vs. ~6000 RPM for normal Sierra clocks). And I believe some Cosworth clocks don't even have the red line at all.
Toe Knee
11
Jan 20, 2010 09:03 PM
burnzy
Jan 1, 2009 01:36 PM
RoyP
Ford Escort RS Cosworth
27
Dec 19, 2007 06:48 PM
Mr.Ford
Sep 12, 2007 10:22 PM
JohanRS
Feb 2, 2006 11:45 AM
