Coil pack
Hi need help with a coil pack problem is i bought an zvh engine and it's got an coil pack on it instead of distributor and iv got a l6 management with no coil pack plug how do I solve that problem I want to stick with coil pack it's a efi
Do you have the cossie loom? If so you will need a wasted spark sub loom about 60 quid. Has your level 6 been converted to wasted spark? If not thats the cost on the MSD site.
Then it will require a map.
Cheaper way is rs turbo ofab ecu loom and associated parts edis 4 etc.
Hope this helps
Hope this helps
IANS2RST
43
Sep 15, 2007 06:21 PM
GUZZLER
15
Jul 27, 2007 08:19 PM
alan rainbow
Jun 8, 2005 03:28 PM
Roosie
Aug 16, 2004 11:14 AM
