Would a top feed intercooler improve turbo lag?
Old Dec 3, 2017 | 08:04 PM
turbotrev's Avatar
turbotrev
Default Would a top feed intercooler improve turbo lag?
As said, would a top feed intercooler reduce turbo lag?
Cheers Paul
Old Dec 3, 2017 | 10:53 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Can't see why it would but interested if anyone has experienced reduced lag after fitting one.
Old Dec 4, 2017 | 09:50 AM
t230's Avatar
t230
ive noticed high end VW/AUDI setups some JAP too have smaller entry pipe and a larger outlet pipe to intake....apparently makes difference....
Old Dec 4, 2017 | 02:07 PM
Caddyshack's Avatar
Caddyshack
I guess it would depend on how easily the air flows through the cooler but I do not know the true answer. I guess with lower intake temps using the best coolers you could map and time it based on that?
Old Dec 4, 2017 | 03:03 PM
Ridgey's Avatar
Ridgey
Don't see it could make any significant difference.
Its the volume that has to be pressurised between the turbo and the inlet valves that creates lag the larger that volume is. As this is the volume to be pressurised before the engine cylinders see the boost pressure.
Old Dec 4, 2017 | 06:48 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
It would be interesting to see a back to back dyno run between say airtecs normal 500 style and a airtec 70mm top feed style. I'm betting nothing in it but great if it does reveal a better response.
Old Dec 4, 2017 | 10:48 PM
cossynut2's Avatar
cossynut2
10 Year Member
Cheers Paul
What do you class as turbo lag? If you have significant turbo lag I would suggest there may be other reasons in your engine /electronics or the type of turbo etc that maybe need looking at.
I agree with others that I cant see a top feed intercooler would be any different to a normal intercooler in reducing your turbo lag.
Old Dec 5, 2017 | 07:26 AM
Mark Shead's Avatar
Mark Shead
Not going to male any diff.
Mark
Old Dec 6, 2017 | 10:15 PM
turbotrev's Avatar
turbotrev
[QUOTE=Mad_Mat;6755429]It would be interesting to see a back to back dyno run between say airtecs normal 500 style and a airtec 70mm top feed style. I'm betting nothing in it but great if it does reveal a better response.[/QUOTE
That would be interesting either way
Cheers Paul
Old Dec 6, 2017 | 10:17 PM
turbotrev's Avatar
turbotrev
I don’t have anything at the mo as I sold my old turbo and am still not 100% certain on what my next one will be...
Cheers Paul
siscossie
Sep 1, 2016 05:50 PM
burnzy
13
Aug 31, 2016 07:39 PM
Jan 2, 2004 06:29 PM
Windle
Dec 18, 2003 10:51 PM
