My new wheels tyre sizing 205 4x4 pug
Old Nov 16, 2017 | 10:42 AM
Caddyshack's Avatar
Caddyshack
Default My new wheels tyre sizing 205 4x4 pug
My car currently has 195/45/16 on 7 inch rims (ET25), I tried it on my other set of comps which are 8X16 ET 25 and they poke out a little too much, they do fit but looks over wheeled.
I have just received a set of 8X16 ET 28 from James Kieley on here with a mind to maybe skimming off 2-3mm if they need bringing in a little.
I wonder if 8 inch may be too wide for the front, will try them but they may rub on full lock and the steering lock is poor already.
If I go for 195/45/16 on 7 inch on the front I think I can go for 215/40/16 on the rear and have under 0.7% speedo deviation which I think is fine to not wind up the diffs.
My questions are: 1) Would this look odd? 2) Is there a problem, grip wise or other having wider tyres and rims on the rear of the car when it is 4wd? I have Supra Weir kitted diff in the rear and Quaife in the front with uprated VC in the centre, the diffs are new and tight so not a lot of give in the car.
Car is running 470 bhp and around 500 ftlb torque and 195 tyres look a little skinny on the back
Old Nov 16, 2017 | 11:34 AM
Ridgey's Avatar
Ridgey
Forget the looks, no point having all that power with such skinny tyres.
I'd be trying my hardest to fit the 215/40 all round even if it compromises full lock slightly. And then you know your not having any impact on the 4x4 diff setup.
I seem to be one of a very few running 235 tyres all round on the Saff, its a little work but your standard hot hatch nowadays has this much tyre with a lot less power.
Old Nov 16, 2017 | 11:57 AM
Caddyshack's Avatar
Caddyshack
Thanks, that does make sense. I could then maybe try 215/45 for a bit more tyre wall give. problem there is I would need to buy a tyre to check for rubbing then waste it and try 215/40 if it doesn't work.
I will try the wheels bare first and then consider if I will get them skimmed down a little before going for it with the tyres.
If I go for the engine that I am considering at the moment I think it will need all the grip it can get as it will be a significant hike in power.
Old Nov 16, 2017 | 08:28 PM
Ridgey's Avatar
Ridgey
The wheels you got are nice
You can get grp A nuts on eBay.
Old Nov 20, 2017 | 05:42 PM
Caddyshack's Avatar
Caddyshack
Thanks Ridgey, I have bought some off there.
I am waiting for a Yokohama 215/45 to arrive and be fitted to 1 wheel to,see how it works.
My 195/45s spun up under heavy throttle the other day, I was in 2nd and floored it..it was in low boost too.
