6 degrees rear beam and MT Motorsport
Old Sep 20, 2017 | 02:02 PM
florent78's Avatar
florent78
Default 6 degrees rear beam and MT Motorsport
Hi
I tried several times to call MT motorsport for a 6 degrees rear beam (email as well)
no answer since 2 weeks
the company is still alive ?
where can I ask for a 6 degrees rear beam ?? other company ?
thanks
Old Sep 20, 2017 | 02:24 PM
Caddyshack's Avatar
Caddyshack
MK Motorsport make them and he often has them in stock. You can get them to take a Supra diff if you want and also lugs to take his bladed anti roll bar if you want it.
07753 440 553
Old Sep 20, 2017 | 02:30 PM
Caddyshack's Avatar
Caddyshack
I have been wrong before but doesn't MK make them for MT anyway?
Old Sep 20, 2017 | 02:38 PM
c20tbo's Avatar
c20tbo
Yes that's correct Toby
Old Sep 20, 2017 | 05:00 PM
Rsmat's Avatar
Rsmat
Had a fully adjustable MK on mine what a piece of art
Old Sep 20, 2017 | 06:25 PM
Adam-M's Avatar
Adam-M
His work is the best no doubt about it
Old Sep 20, 2017 | 07:25 PM
RSCossieGaz's Avatar
RSCossieGaz
What is the cost of one of these beams?
Old Sep 20, 2017 | 07:32 PM
Caddyshack's Avatar
Caddyshack
Probably worth calling him for an up to date price. Having a beam to trade in might help. His number is in my earlier reply.
Old Sep 20, 2017 | 08:50 PM
3doorcozmess's Avatar
3doorcozmess
MK is good but dont expect to receive the beam in the same year you ordered it.
i would talk to SCS unless MK can give you a promised date of delivery your happy with.
cheers si
Old Sep 21, 2017 | 07:53 AM
3drRich's Avatar
3drRich
Mark from mt is one of the best guys I've ever dealt with. I know he's been really busy lately but unlike him not to respond. I've pmd you his mobile number and if he doesn't answer leave him a voicemail.
Old Sep 21, 2017 | 03:22 PM
turbotrev's Avatar
turbotrev
Give scs a ring mate
Cheers Paul
Old Sep 22, 2017 | 08:24 AM
nixon_2wd's Avatar
nixon_2wd
Agreed
Old Sep 24, 2017 | 08:06 AM
robrs2's Avatar
robrs2
Look up MC Fabrications on facebook. I have one of his beams
Old Sep 24, 2017 | 08:10 AM
Adam-M's Avatar
Adam-M
I don't think his beam is in the same league but is a lot cheaper.
Old Sep 24, 2017 | 12:59 PM
dan le moignan's Avatar
dan le moignan
Those ones seem good value at Ł800, but guess they are fairly unknown/ proven?
Do people find the ride much harsher on rose joints vs bushes?
Old Sep 24, 2017 | 01:38 PM
robrs2's Avatar
robrs2
They are and also they retain all the brackets and fixing that are required for use in a road car. I have seen most of it chopped off the more expensive beams. No fitment problems at all.
The only item i have changed is to add rubber boots to the rose joint to keep the crap out. Mine also has mounts to adjust the ARB location for some adjustment.
Old Sep 24, 2017 | 02:52 PM
Caddyshack's Avatar
Caddyshack
Have you noticed how many threads we get with all this advice and yet the OP doesn't even reply?
Old Sep 25, 2017 | 07:11 AM
robrs2's Avatar
robrs2
If anyone is using a rose jointed beam on the road the joint need to have the boots fitted as it is now an mot fail.
I've not had any problem with joints fitted with boots but have had fail/worn out ones that were just open. They don't like grit and dirt in them there are side seals for the joints but I don't think they will work as well, but I've not used them before.
Old Sep 25, 2017 | 02:49 PM
Caddyshack's Avatar
Caddyshack
My car is rose jointed all round with no boots and it passed the MOT 2 weeks ago. I guess you need to have a nice MOT tester?
Old Sep 25, 2017 | 03:36 PM
c20tbo's Avatar
c20tbo
Ive boots fitted on all my rose joints, MK beam, bladed roll bar setup, only thing I have not put boots on are my wrc tca pins, which I cant get anywhere
MK's beams are a work of art.....
Old Sep 25, 2017 | 06:20 PM
Adam-M's Avatar
Adam-M
Where's best to buy rose joint boots?
Old Sep 25, 2017 | 07:38 PM
Rsmat's Avatar
Rsmat
Loads on eBay mate
Old Sep 26, 2017 | 06:23 AM
c20tbo's Avatar
c20tbo
McGill motorsport
