Sierra handbrake/parking warning light
Aug 27, 2017 | 09:32 PM
My sierra saph handbrake/parking warning light on dash does not work/has stopped working a while ago bulbs are ok and switch on handbrake is also ok, so can anyone tell me how it works so I can trace it and find fault (possibly broke wire)
Many thanks cheers
Aug 28, 2017 | 06:04 AM
Does the light work for the low fluid sender in the brake fluid reservoir? If you lift the sensor out of the fluid the light should come on.
Aug 28, 2017 | 03:32 PM
Quote:
Originally Posted by
Marc sierra
Marc its this warning panel!
Aug 28, 2017 | 04:43 PM
I know. That also lights up when your brake fluid is low.
Aug 28, 2017 | 05:27 PM
Will try tomorrow and let you know, but I want to know how the hand brake is wired
Aug 28, 2017 | 08:37 PM
IIRC there is 12V on the bulb and the hand brake switch (or low fluid switch) connects it to ground to make the light come on.
Aug 28, 2017 | 09:41 PM
Marc sierra
Correct (as will low pressure)
Martin
Aug 28, 2017 | 09:56 PM
so if i mess with fluid senso and light doesnt come on whats my next move?
Does the wire from handbrake switch go straight to the clocks?
Aug 28, 2017 | 10:16 PM
doga-ot
Break in wiring, missing supply, or faulty bulb.
It will do, but I suspect there is a common join, where they go off separate ways.
Martin
Aug 28, 2017 | 10:29 PM
Bulb is good clocks are new and bulbs are brand new
Aug 28, 2017 | 10:39 PM
Just read your original post.
Most likely a bad connection then, you need to do what has been said first though.
Martin
