Sierra handbrake/parking warning light
27-08-2017, 09:32 PM
My sierra saph handbrake/parking warning light on dash does not work/has stopped working a while ago bulbs are ok and switch on handbrake is also ok, so can anyone tell me how it works so I can trace it and find fault (possibly broke wire)
Many thanks cheers
28-08-2017, 06:04 AM
Does the light work for the low fluid sender in the brake fluid reservoir? If you lift the sensor out of the fluid the light should come on.
28-08-2017, 03:32 PM
Quote:
Originally Posted by
Marc sierra
Marc its this warning panel!
28-08-2017, 04:43 PM
I know. That also lights up when your brake fluid is low.
28-08-2017, 05:27 PM
Will try tomorrow and let you know, but I want to know how the hand brake is wired
28-08-2017, 08:37 PM
IIRC there is 12V on the bulb and the hand brake switch (or low fluid switch) connects it to ground to make the light come on.
28-08-2017, 09:41 PM
Marc sierra
Correct (as will low pressure)
Martin
28-08-2017, 09:56 PM
so if i mess with fluid senso and light doesnt come on whats my next move?
Does the wire from handbrake switch go straight to the clocks?
28-08-2017, 10:16 PM
doga-ot
Break in wiring, missing supply, or faulty bulb.
It will do, but I suspect there is a common join, where they go off separate ways.
Martin
28-08-2017, 10:29 PM
Bulb is good clocks are new and bulbs are brand new
28-08-2017, 10:39 PM
Just read your original post.
Most likely a bad connection then, you need to do what has been said first though.
Martin
