Wheel Bearings
Old Aug 19, 2017 | 03:38 PM
PYE WHITE's Avatar
PYE WHITE
Default Wheel Bearings
Hiya,
I have a 2wd sapphire cosworth & I must have gone through 10-12 wheel bearings over the last 4/5 years. I do about 4000 miles a year & I have changed them on all 4 corners numerous times. I was wondering if anyone else had this issue.
Simon
Old Aug 19, 2017 | 03:54 PM
Caddyshack's Avatar
Caddyshack
Not that I have read about, there was one that had judder after a ring trip which had new bearings to try and solve it.
I wonder if your stub axles might have play in them perhaps or something like that?
I have the Wrc hubs on my 4x4 pug cossie and those bearings are huge, I believe they are Ford Transit bearings.
Old Aug 19, 2017 | 04:35 PM
PYE WHITE's Avatar
PYE WHITE
I have bought bearings from Graham Goode, Anembo Engineering, Burton & other motor factors all with the same results. It seems strange that all four corners go as well. My last 2 drivers side fronts have done 200 & about 1000 miles before going.
Old Aug 19, 2017 | 05:03 PM
Caddyshack's Avatar
Caddyshack
That doesn't make sense at all. I assume you can't just tighten them after 1000 miles once bedded in?
Old Aug 19, 2017 | 05:29 PM
PYE WHITE's Avatar
PYE WHITE
Not sure to be honest. Sometimes the bearings have collapsed, or just whine like hell. I'm not sure if the grease is up to standard as it looks like the bearing & grease have got too hot. I always tighten the nuts up to the correct torque settings so not sure must to do.
Old Aug 19, 2017 | 10:02 PM
cossynut2's Avatar
cossynut2
10 Year Member
There is something going on that is not normal. I recently had new rear wheel bearings fitted on the rear of my 2wd Saff after 67,000 miles. I am not suggesting that you have done anything wrong but maybe you have misunderstood part of the installation prochedure or torque settings?
Old Aug 20, 2017 | 07:41 AM
PYE WHITE's Avatar
PYE WHITE
My father & I have change the bearings half of the time & the rest have been done by garages. I do wonder if we are doing something wrong but father is a fully qualified mechanic & has done this job many times over the years.
We have just bought a new torque wrench, fingers crossed this solves the issue.
Old Aug 22, 2017 | 06:03 AM
The Crocodile Hunter's Avatar
How strange? Something isn't right. As you've been through so many it can't be the bearings at fault and as its all four it can't be that all the hubs are at fault surely?
Maybe it is the grease as you suggest?
Ive not changed a bearing on mine in the 12 years I've owned it.
Old Aug 22, 2017 | 12:28 PM
PYE WHITE's Avatar
PYE WHITE
We have bought some new grease now, but we normally use the grease supplied with the bearings. You would have thought that that would have been ok.
Old Aug 22, 2017 | 04:09 PM
Caddyshack's Avatar
Caddyshack
How are you getting the old bearings out and new ones in?
Old Aug 22, 2017 | 07:50 PM
PYE WHITE's Avatar
PYE WHITE
Tapping the old ones out with a drift & pressing the new ones in.
Old Aug 22, 2017 | 08:11 PM
Caddyshack's Avatar
Caddyshack
I can't work out what is going wrong
Old Aug 23, 2017 | 06:19 AM
Are you using paticularly big wheel spacers or anything like that?
Old Aug 23, 2017 | 09:15 AM
cossynut2's Avatar
cossynut2
10 Year Member
It makes no sense to me either, I have had my 2wd Saff for 22 years, done 67,000 miles in that time to bring the mileage now to 107,000 and I have just changed the rear wheel bearings. Only one side was worn but I changed both to be sure.To be going through all four wheel bearings more than once in such a low mileage is a mystery.
Old Aug 26, 2017 | 11:25 AM
PYE WHITE's Avatar
PYE WHITE
I don't have any spacers but the wheels are ET33, do you think this can you be an issue?
Old Aug 26, 2017 | 03:10 PM
Adam-M's Avatar
Adam-M
Et33 is fine on a saph
Old Aug 27, 2017 | 09:02 AM
PYE WHITE's Avatar
PYE WHITE
That was my thoughts as well
Old Aug 28, 2017 | 08:53 PM
So it's got nothing to do with spacers, and we assume that the bearings and hubs are not at fault.
It must have something to do with the method used for pressing them in or the torque setting?
Maybe your old torque wrench has been doing you no favours at all?
Old Aug 29, 2017 | 11:20 AM
PYE WHITE's Avatar
PYE WHITE
I have just bought a new torque wrench so hopefully that does the trick.
Old Aug 30, 2017 | 07:24 PM
Are you wheels correctly balanced?? Ive heard of wheels not been balanced and the vibration damages the bearings.
Old Aug 31, 2017 | 07:42 AM
MONSTER's Avatar
MONSTER
Stupid question but are you packing them prior to fitting?
Old Aug 31, 2017 | 12:05 PM
PYE WHITE's Avatar
PYE WHITE
The front drivers wheel does have a slight buckle but they are all balanced. May be time for some new wheels but that doesn't explain all of the bearings going, there not all buckled
Old Aug 31, 2017 | 12:06 PM
PYE WHITE's Avatar
PYE WHITE
The bearings are packed with grease but my father isn't convinced the grease that comes with the bearings is up to scratch.
