Focus Auto keeps stalling! Help
Old Aug 15, 2017 | 11:16 AM
Jay_61279uk's Avatar
Jay_61279uk
Default Focus Auto keeps stalling! Help
Hey hopefully someone can shed some light on this, my partner has an 02 plate focus 1.6 auto that keeps stalling, it doesnt happen all the time, more so in wet weather though. Its usually when slowing down thn accelerating off at junction etc the battery light will come on then split second later car will chug lose power and stall. I have recently changed timing and aux belt, fuel and oil filters spark plugs, exhaust and lambda sensor, also when driving in bad wet weather the engine light will come on with something o2 sensor related but clears when wipe code!!
Old Aug 15, 2017 | 11:58 AM
Rowe's Avatar
Rowe
Skint
take it to a garage. Diagnosing it over the internet could lead you along a pointless trail of costs
Old Aug 15, 2017 | 12:09 PM
RichieST's Avatar
RichieST
Idle control valves are the usual culprit, along with split vacuum hoses. But as said I would get a proper diagnosis done.
Old Aug 15, 2017 | 12:57 PM
Jay_61279uk
Will a diagnostic machine show anything up though if theres no eml on? Cleared codes on handheld reader last time light came on
Old Aug 15, 2017 | 05:20 PM
RichieST's Avatar
RichieST
Not all dtc's will bring the light on. It's worth plugging it in to see if anything is stored.
Old Aug 15, 2017 | 06:47 PM
Fordmad!'s Avatar
Fordmad!
I'd check the vacuum hose hasnt split. Mine did last year would cut out and rev on its own. They were ruined completely. Changed them with some hose I cut off the top water hose Cured it completely
Old Aug 16, 2017 | 10:13 AM
Jay_61279uk
Cheers ill give hoses a looking over! Doesnt cut out all time, just every cpl days
Old Aug 16, 2017 | 08:20 PM
carl84's Avatar
carl84
by memory there is a t piece breather that splits under the inlet manifold, spray some penetration spray around it and with engine running and see if the revs drop
Old Aug 19, 2017 | 01:26 PM
Jay_61279uk
Had the car for a diagnostic check and come up with no faults
