Wastegate Actuator
Old Aug 7, 2017 | 07:35 PM
cossie330's Avatar
cossie330
Default Wastegate Actuator
Hi guys, what actuators are you running on stage 3 4x4 saff Cossie? I've had 2 Garrett -31 fail
cheers Jason
Old Aug 7, 2017 | 08:47 PM
dan le moignan's Avatar
dan le moignan
Were they genuine Garret actuators?
-31 should be fine I would have thought.
Old Aug 7, 2017 | 08:52 PM
cossie330's Avatar
cossie330
yeah both genuine Garrett -31
Old Aug 7, 2017 | 09:35 PM
Ridgey's Avatar
Ridgey
If a minimum boost of 14 psi would suit you, you could use a Garrett -34
Old Aug 7, 2017 | 09:47 PM
cossie330's Avatar
cossie330
Mine normally boosts to 22psi
Old Aug 7, 2017 | 10:22 PM
cossie330's Avatar
cossie330
Can a -34 be used on a t3 turbo?
Old Aug 8, 2017 | 11:59 AM
Guinnless's Avatar
Guinnless
A correctly set up -31 should last for 10 years plus.
Half a hole preload and jet Amal valve to suit.
Job done.
Old Aug 8, 2017 | 01:42 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
In what way did it fail. Is the rod alignment good and as already said how much preload.
I had a -34 on mine and was fine for stg3 23>24psi.
Old Aug 8, 2017 | 03:55 PM
cossie330's Avatar
cossie330
I think whoever installed it our way to much preload on it and the spring has gone weak causing the watergate to open and not hold boost, I'll order -34, set that correctly and fit my new electronic boost controller.
Cheers Jason
Old Aug 8, 2017 | 06:39 PM
Ridgey's Avatar
Ridgey
I don't think you'll have the same problem if you are fitting a boost controller, you could either use a -34 or -31, the boost controllers solenoid should bleed sufficiently off for either to be used without excessive preloads.
Old Aug 8, 2017 | 06:52 PM
cossie330's Avatar
cossie330
cheers mate, appreciate the help
