What is roughly the maximum power you can achieve with a regular stage 3 conversion on a t34.48 running a 4x4 intercooler?
Best to change to a 500 style one or is the 4x4 one still efficient up to the 360/380hp range?
Best to change to a 500 style one - Yes definitely. Heat is the enemy.
or is the 4x4 one still efficient up to the 360/380hp range - I doubt it unless its -10c outside.
I think even an RS500 one is becoming inefficient at 400 bhp..compared to alternatives, sure it will be ok but you will still see quite high intake temps, especially on a hot day.
I said rs500 style (like airtec etc,) not literally an rs 500 item.
He's def not gonna buy a spec-r cooler for a grand for use on a stage 3+ under 400hp
