2WD Saff tyre size + type on 8X18 mo6s ET35.
Old May 20, 2017 | 01:19 PM
Sierrasideways's Avatar
Sierrasideways
Default 2WD Saff tyre size + type on 8X18 mo6s ET35.
Nowadays what tyres are you guys running?....Michelin/Toyo/Bridgestone/Continental/Dunlop etc. and what size, 225/235/40/35, can I use running comps mo6s (form an orderly queue for the tut tutting ), 6 degree beam, AP 6 pots 9040, konis and bayjoos and arches aren't rolled but will be if necessary. Finally have the parts mentioned except tyres so if I get a good indication of the right size to use, I can start fitting the lot.
Your input and views is much appreciated
Can't think of anything I've left out...if I have, do tell.
CheeRS lads.
Philip.
Old May 20, 2017 | 03:21 PM
cossynut2's Avatar
cossynut2
10 Year Member
CheeRS lads.
Philip.
This is a question that comes up quite often and usually gets a lot of different answers. It seems to me its not a straight forward case of what will fit ok. Some people say they have 235/40/18s with 8 inch wide wheels others have smaller wheels and tyres as the bigger ones foul the bodywork.If your car is lowered and you want big wheel and tyre combinations then the arches need to be rolled in most cases.My advice would be if you can, trial fit first before you commit to spending a lot of money on what you hope will fit ok only to find they dont!
On my 2wd Saff which is lowered with rolled arches I have 215/40/17 Federal RSR tyres which seem pretty good but of course there are loads to choose from, no doubt others have their favourites as well.
Koni Shocks with Eibach 35mm lowering springs and rolled arches. ET35 offset 17x7.5 old school OZ Cronos alloys.
Even with rolled arches there isnt a lot of room between the tyres and bodywork.
Old May 20, 2017 | 03:40 PM
costina's Avatar
costina
Live long and prosper!!
215.35.18 Toyo was on mine running std height springs and koni's.
Worked fine for me on et42 focus RS rims.
Old May 21, 2017 | 08:31 AM
Cos500's Avatar
Cos500
This is what I have on mine, no catching and not rolled arches on 2wd, needed 18's to cover ap6 pots, couldnt fit anything different than 215/35/18 as they would catch the arches, antiroll bar and shocker.
Old May 21, 2017 | 05:14 PM
Sierrasideways
Thanks for the replies guys. 215/35/18 seems to be popular. Was thinking possibly fitting wider tyres at the back, possibly 235s, to put the power down better and for more grip. Mightn't be right about that though, that's why I'm asking Unfortunately I don't have the option of trial fitting as I'll be ordering the tyres either online or from the tyre place in my home town so can't really order 2 sets and say I only want 1 if you know what I mean...Roads are shite here so kind of want as much sidewall as I can fit like 40 instead of 35.
I was hoping to fit 225/40/18 all round. Hope they won't rub or hit the shocks at the front. With my suspension setup do you think I'd get away with that?
Edit: I can get Toyo R888R for about Ł190 each...may be a stupid question but are these road legal? Just heard everyone raving about them so looking for your thoughts...
CheeRS.
Philip.
Old May 21, 2017 | 05:31 PM
costina's Avatar
costina
Phillip you cant run 225 40 18 on a saff they will rub either on the strut or the arch. You might get away with it on the rear but you will have to lose the arch liners imo.
Paul
Old May 21, 2017 | 08:29 PM
Sierrasideways
Thanks Paul. Looking like 215/35/18 so as I don't want to remove the arch liners. Will get some ordered tomorrow hopefully.
Philip.
Old May 21, 2017 | 10:16 PM
cossynut2's Avatar
cossynut2
10 Year Member
CheeRS.
Philip.
Tyres like mine, Federal 595RSR and ToyoR888R are track day road legal and do offer very high levels of dry road grip.If you are running a big power engine in a 2wd Saff you do have to be more careful in the wet!
Old May 21, 2017 | 10:27 PM
Cos500's Avatar
Cos500
I'd just stick with 215/35/18, looked at 225 for the same reason on rear but as stated I think I'd have been changing them again.
R888 have a solid tyre wall and on my evo the ride was terrible, good for the track yes but after 2 track days they were dead and expensive to replace, I've gone for toyo proxes T1R for the cossie, good price and excellent all round tyre also very good on the track including Nurburgring, where other tyres failed the toyos did not.
Old May 22, 2017 | 08:23 PM
Sierrasideways
Cheers mate. Not much point in myself getting them after rethinking it, as shite weather here all the live long day and shouldn't be doing any track time until next year presumably. Have had a few moments in the wet already so hopefully with new shoes it'll be grippier! Beam should help. Have a full alignment setup booked in too. Just need to wait for my ordered parts and order the tyres. Then the fun can commence
Cheers mate. I'm actually thinking along the same lines as yourself and can get a good enough price on T1Rs so will probably give them a go. Good reviews mostly and they're priced right. I could get more expensive types but I'll try these first as I'm getting a deal on them already so saving myself a few quid that I wouldn't on the dearer ones. Need to get them fitted asap
Thanks for the replies, great help as per usual
Philip.
Old Dec 4, 2017 | 09:18 PM
Adam-M's Avatar
Adam-M
Any updates mate? Id like to run 225/35/18's on the rear of mine to at least try and get some wet grip but don't know if I'll need my arches rolled, like you I have et35 comp m06. Fronts I may have to stick with 215's.
Old Dec 4, 2017 | 10:41 PM
cossynut2's Avatar
cossynut2
10 Year Member
If you have lowered your car you will need to get the arches rolled for sure if you are going to try and run the wider 225 width.
Old Dec 5, 2017 | 03:52 AM
2wd's Avatar
2wd
225/35x18 up front and 235/35x18 rear and rolled Arches ..
Old Dec 5, 2017 | 06:43 AM
cossynut2's Avatar
cossynut2
10 Year Member
Can you tell us what you have had to do to fit such wide tyres on your Saff? What wheels and what off set are they? How much modification to the arches have you done? Do you still have arch liners fitted?
I tried a 225 wide tyre on the front of my lowered Saff and it fouled on the bodywork as soon as the wheel was turned left or right.
Old Dec 5, 2017 | 11:14 AM
Adam-M's Avatar
Adam-M
Any pics of saphs with rolled arches?
Old Dec 5, 2017 | 06:00 PM
cossynut2's Avatar
cossynut2
10 Year Member
There are a couple of mine in this thread.
Old Dec 5, 2017 | 08:44 PM
Sierrasideways
Hi Adam,
I went with 215/35/18s Toyo T1Rs and they're great so far but still rub a bit on the front when turning hard. Will update you when arches are rolled and respect done....hopefully soon after Xmas!
The other lads' replies seem to be way more informative though which is interesting reading
Philip.
Old Dec 5, 2017 | 10:11 PM
jason_nike's Avatar
jason_nike
Been running 215/35/18 for ages, front arches rolled, rears are standard
Attached Thumbnails 2WD Saff tyre size + type on 8X18 mo6s ET35.-img_3040.jpg   2WD Saff tyre size + type on 8X18 mo6s ET35.-image_zps0uvgghip.jpeg
Old Dec 6, 2017 | 07:19 AM
cossynut2's Avatar
cossynut2
10 Year Member
jason_nike Nice looking Saff. I am suprised you have not had any issues with the rear tyres touching the bodywork. I think it must depend a lot on how much lower the suspension is, the rolling radius on my 17inch wheels with 215/40/17s must be about the same as yours with the 18inch wheels but I had to have the arches rolled for clearance on mine.
Old Dec 6, 2017 | 08:55 PM
jason_nike's Avatar
jason_nike
It seems every car is different, some rub more than others strangely enough.
Old Dec 7, 2017 | 04:35 PM
215/35/18s for me too. I have maxxis tyres on mine. There ok for a cheap tyre. I dont think the ride is as nice as with 17s on.
Old Jan 12, 2019 | 09:46 AM
ajs's Avatar
ajs
Salutations, I've been reading these forums for a long time from New Zealand, but just joined now to reply to this one, and apologies for being late into the discussion.
Interesting thread. Just to be a pain, I'm going to throw another factor into the mix (yeah, I'm one of 'those'). My Saph is on 225/35/18 Bridgeys all round (the 18" RS Sharkstooth alloy). Yes, as pointed out, they rub at the front, or they did.
By the time I got her, someone had replaced the lower suspension arm bushes with nolathane ones. Yes, there are many who would swear black-and-blue that that these are the business, but I'm not so keen. For one, they have a tendency to just implode, as opposed to 'wearing' - I have seen this several times first hand, whereby the bush is just 'gone', leaving very fine fragments of blue speckled all over the rim, and a lot of free-play in the front wheel. On the open road or under decent boost, this could be catastrophic.
Anyhooo, I gave these the flick, went back to factory-spec'd rubber bushes, and voila: the rubbing totally disappeared. Furthermore, she handles much better; in fact, it's almost like she is on rails.
Now I know, we're all running different gear, but I thought that this was worth noting. I chatted to my mechanic, who is very, very good, and we came to the conclusion that, as the Cos was engineered for such performance and many parts were engineered to operate with mere millimetres of 'play', something like a slightly different (not factory spec) bush can make that much of a difference.
Hope this adds another string to the thread (if that even makes sense
Old Jan 12, 2019 | 01:05 PM
turbotrev's Avatar
turbotrev
For normal road tyres and no grief go for 215/35/18’s.
Start going bigger and you may run into issues.
Also so don’t forget the track tyres like r888’s etc have a bigger diameter and width than a road tyre of the same size, so they will come up bigger and possibly rub.
I had t1r toyos on my old 18” rims and with over 500hp it was like driving on ice, they were terrible.
Mid you need grip go with some decent track tyres.
Leave the 18’s for show type use
Cheers Paul
Old Jan 20, 2019 | 06:58 AM
Adam-M's Avatar
Adam-M
Cheers Paul
I wouldn’t say 18’s where show use only
Old Jan 20, 2019 | 09:47 PM
turbotrev's Avatar
turbotrev
They may as well be if you can’t get decent tyres fitted to em and your running big power...
Cheers Paul
Old Jan 27, 2019 | 11:27 PM
scoooby slayer's Avatar
scoooby slayer
Cheers Paul
I wish I had filmed my supra before and after fitting tyres, going from pirelli p zeros to r888s on 19" rims with 800 hp was a night and day difference, I massively rate r888s brilliant tyres ime
It was no grip at 100 mph to full grip at 60 mph in the dry
This was with r888s
https://youtu.be/4iCg59ZbbSg
Old Jan 28, 2019 | 01:46 PM
Adam-M's Avatar
Adam-M
Cheers Paul
just like saying smaller wheels are show use as you can only run small brakes
Seems 235 35 18 is possible with arch rolling which is the route im going to take
Old Jan 28, 2019 | 01:58 PM
scoooby slayer
Rods car runs 235/40/18s on the back, not sure what tyres are but I will report here once I have the cars here I think there r888s on the back
Old Jan 28, 2019 | 07:34 PM
Adam-M's Avatar
Adam-M
be interesting to see how much arch work was done mate, my back arches have been rolled flush so if yours have been done the same I’ll go with that size tyre on the rear
