2WD Saff tyre size + type on 8X18 mo6s ET35.
Nowadays what tyres are you guys running?....Michelin/Toyo/Bridgestone/Continental/Dunlop etc. and what size, 225/235/40/35, can I use running comps mo6s (form an orderly queue for the tut tutting ), 6 degree beam, AP 6 pots 9040, konis and bayjoos and arches aren't rolled but will be if necessary. Finally have the parts mentioned except tyres so if I get a good indication of the right size to use, I can start fitting the lot.
Your input and views is much appreciated
Can't think of anything I've left out...if I have, do tell.
CheeRS lads.
Philip.
CheeRS lads.
Philip.
CheeRS lads.
Philip.
CheeRS lads.
Philip.
On my 2wd Saff which is lowered with rolled arches I have 215/40/17 Federal RSR tyres which seem pretty good but of course there are loads to choose from, no doubt others have their favourites as well.
Koni Shocks with Eibach 35mm lowering springs and rolled arches. ET35 offset 17x7.5 old school OZ Cronos alloys.
Even with rolled arches there isnt a lot of room between the tyres and bodywork.
Sierrasideways (21-05-2017)
This is what I have on mine, no catching and not rolled arches on 2wd, needed 18's to cover ap6 pots, couldnt fit anything different than 215/35/18 as they would catch the arches, antiroll bar and shocker.
Thanks for the replies guys. 215/35/18 seems to be popular. Was thinking possibly fitting wider tyres at the back, possibly 235s, to put the power down better and for more grip. Mightn't be right about that though, that's why I'm asking Unfortunately I don't have the option of trial fitting as I'll be ordering the tyres either online or from the tyre place in my home town so can't really order 2 sets and say I only want 1 if you know what I mean...Roads are shite here so kind of want as much sidewall as I can fit like 40 instead of 35.
I was hoping to fit 225/40/18 all round. Hope they won't rub or hit the shocks at the front. With my suspension setup do you think I'd get away with that?
Edit: I can get Toyo R888R for about Ł190 each...may be a stupid question but are these road legal? Just heard everyone raving about them so looking for your thoughts...
CheeRS.
Philip.
CheeRS.
Philip.
Cos500 (21-05-2017)
CheeRS.
Philip.
CheeRS.
Philip.
I'd just stick with 215/35/18, looked at 225 for the same reason on rear but as stated I think I'd have been changing them again.
R888 have a solid tyre wall and on my evo the ride was terrible, good for the track yes but after 2 track days they were dead and expensive to replace, I've gone for toyo proxes T1R for the cossie, good price and excellent all round tyre also very good on the track including Nurburgring, where other tyres failed the toyos did not.
Thanks for the replies, great help as per usual
Philip.
Any updates mate? Id like to run 225/35/18's on the rear of mine to at least try and get some wet grip but don't know if I'll need my arches rolled, like you I have et35 comp m06. Fronts I may have to stick with 215's.
Can you tell us what you have had to do to fit such wide tyres on your Saff? What wheels and what off set are they? How much modification to the arches have you done? Do you still have arch liners fitted?
I tried a 225 wide tyre on the front of my lowered Saff and it fouled on the bodywork as soon as the wheel was turned left or right.
Any pics of saphs with rolled arches?
I went with 215/35/18s Toyo T1Rs and they're great so far but still rub a bit on the front when turning hard. Will update you when arches are rolled and respect done....hopefully soon after Xmas!
The other lads' replies seem to be way more informative though which is interesting reading
Philip.
Been running 215/35/18 for ages, front arches rolled, rears are standard
jason_nike Nice looking Saff. I am suprised you have not had any issues with the rear tyres touching the bodywork. I think it must depend a lot on how much lower the suspension is, the rolling radius on my 17inch wheels with 215/40/17s must be about the same as yours with the 18inch wheels but I had to have the arches rolled for clearance on mine.
It seems every car is different, some rub more than others strangely enough.
Salutations, I've been reading these forums for a long time from New Zealand, but just joined now to reply to this one, and apologies for being late into the discussion.
Interesting thread. Just to be a pain, I'm going to throw another factor into the mix (yeah, I'm one of 'those'). My Saph is on 225/35/18 Bridgeys all round (the 18" RS Sharkstooth alloy). Yes, as pointed out, they rub at the front, or they did.
By the time I got her, someone had replaced the lower suspension arm bushes with nolathane ones. Yes, there are many who would swear black-and-blue that that these are the business, but I'm not so keen. For one, they have a tendency to just implode, as opposed to 'wearing' - I have seen this several times first hand, whereby the bush is just 'gone', leaving very fine fragments of blue speckled all over the rim, and a lot of free-play in the front wheel. On the open road or under decent boost, this could be catastrophic.
Anyhooo, I gave these the flick, went back to factory-spec'd rubber bushes, and voila: the rubbing totally disappeared. Furthermore, she handles much better; in fact, it's almost like she is on rails.
Now I know, we're all running different gear, but I thought that this was worth noting. I chatted to my mechanic, who is very, very good, and we came to the conclusion that, as the Cos was engineered for such performance and many parts were engineered to operate with mere millimetres of 'play', something like a slightly different (not factory spec) bush can make that much of a difference.
Hope this adds another string to the thread (if that even makes sense
For normal road tyres and no grief go for 215/35/18’s.
Start going bigger and you may run into issues.
Also so don’t forget the track tyres like r888’s etc have a bigger diameter and width than a road tyre of the same size, so they will come up bigger and possibly rub.
I had t1r toyos on my old 18” rims and with over 500hp it was like driving on ice, they were terrible.
Mid you need grip go with some decent track tyres.
Leave the 18’s for show type use
Cheers Paul
Cheers Paul
Cheers Paul
Cheers Paul
I wish I had filmed my supra before and after fitting tyres, going from pirelli p zeros to r888s on 19" rims with 800 hp was a night and day difference, I massively rate r888s brilliant tyres ime
It was no grip at 100 mph to full grip at 60 mph in the dry
This was with r888s
https://youtu.be/4iCg59ZbbSg
be interesting to see how much arch work was done mate, my back arches have been rolled flush so if yours have been done the same I’ll go with that size tyre on the rear
