T3 TURBO WILL IT RUN????????
Old Apr 10, 2005 | 09:30 AM
dan druff's Avatar
dan druff
Default T3 TURBO WILL IT RUN????????
IF I UPGRADE TO GREENS,330HP CHIP AND 3 BAR WILL I HAVE TO CHANGE MY T3 TURBO .
ANY ADVICE WILL BE APPRECIATED
Old Apr 10, 2005 | 09:41 AM
Toad_RS's Avatar
Toad_RS
i will run ok on a t3. but a t34 would give you more power,t34 and a 500 cooler you will get about 350 bhp
Old Apr 10, 2005 | 09:54 AM
Antilagnos8inj2wd's Avatar
Antilagnos8inj2wd
NOPE
Old Apr 10, 2005 | 05:37 PM
foreigneRS's Avatar
foreigneRS
Testing the future
get a chip appropriate for the turbo.
a lot of so called '330' chips are written for T34. using one with a t3 will give you too much fuel at top end (as a t34 flows more air than a t3 for the same boost pressure). this will be detrimental to both the engine and your wallet (too much fuel results in crap economy, fouled plugs, soot build up on head / valves, etc, etc).
Old Apr 11, 2005 | 06:17 PM
righthooker's Avatar
righthooker
exactly i got greens and all the gubbins on a t3 turbo and got a chip of stu @msd to run it
Old Apr 11, 2005 | 06:20 PM
dan druff's Avatar
dan druff
do you know roughly what power it gave
Old Apr 11, 2005 | 09:52 PM
3DOOR ARY's Avatar
3DOOR ARY
just put stage 3 on mine,was gonna keep t3 but got told it wouldnt last very long
due to the higher boost it would be running so put on a t34.all i can say is if you can afford a t34 get 1 you will not be sorry.
scs(harvey gibbs)at werrington did the work for me,very impressed.
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
IAN RS2k
Aug 18, 2015 07:51 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
