Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
1988. Xr3i mfi bad cold start and misfire
Old Dec 21, 2016 | 10:37 PM
focus_joe's Avatar
focus_joe
Default 1988. Xr3i mfi bad cold start and misfire
hi guys just bought a xr3i the problem I can't get to the bottom of is when you first start it it will cut out and then start again and so on for 5 mins until walms up and misfires until at normal temperature (I think as temp gauge also doesn't work but changed the sensor?)
im stumped, pulled cold start injector out and that squirts when you turn the key changed plugs and fuel filter. Before I bought it the previous owner said it would boil over but he changed thermostat and has not since. The gauge and fan does not kick in so not sure what temp it's running but it does not boil over now.
Any ideas guys? Cars going into paint next week and hoping to get engine fault sorted to get mot and ready for summer
Old Dec 23, 2016 | 11:41 AM
stevo123's Avatar
stevo123
Hi. I just posted a reply but it did not work.
Try the WUR (Warm up regulator). They regulate fuel pressure during warm up cycle. Disconnect electric plug from cold start valve - not needed in our climate really.
Some K-Jet cars, I think VW, have an adjustable WUR and may well work with the XR. Have a google on them and see if it's failure matches your symptoms.
Maybe try a known working replacement first as fault finding?
Steve
Old Dec 23, 2016 | 03:21 PM
focus_joe's Avatar
focus_joe
Thanks for your reply, were is the WUR located ?
regarfs
joe
Old Dec 24, 2016 | 01:01 PM
stevo123's Avatar
stevo123
It's in front of the throttle body but behind the rocker cover. 2 red pipes and one electrical connection.
Old Dec 24, 2016 | 01:10 PM
haz87's Avatar
haz87
Just check the fuel pressure at cold through to hot. Will soon tell you what the WUR is doing. Golf GTI 16v/Capri/many other WURS can be modified to be adjustable as mentioned - always a good mod.
Old Dec 25, 2016 | 05:37 PM
focus_joe's Avatar
focus_joe
Sorry for the dumb questions I'm a carb man myself
what's the procedure to check the wur pressure ?
Old Jan 10, 2017 | 10:57 PM
focus_joe's Avatar
focus_joe
how is it adjusted on the xr3i I don't see any adjusting screws or anything unable to test
Old Jan 11, 2017 | 05:10 AM
haz87's Avatar
haz87
System pressure can be adjusted via shims. The design of the WUR means Control pressure is not adjustable easily - however not impossible! The how-to is fairly long tho - have you confirmed you need to be adjusting pressure yet?
Old Jan 11, 2017 | 12:56 PM
focus_joe's Avatar
focus_joe
No not yet, still need to check pressure but unsure how to go about testing it
regards
Old Jan 11, 2017 | 12:58 PM
haz87's Avatar
haz87
Ignore the WUR adjustment (as thats a 16v Golf WUR - xr3i uses the same WUR as an 8v Golf) but it shows you how to set up the pressure test at least
