Wheels and Tyres Wheels and Tyres for all Ford's
Bolt holes in wheels too big?
Old Nov 27, 2016 | 11:30 PM
Daan's Avatar
Daan
Default Bolt holes in wheels too big?
Hi guys,
I have just bought some st170 focus wheels for my fiesta mk6 2007. The wheel sizes should fit and the bolt pattern is the same at 4x208.
Today I tried to fit one of the wheels when I realised that the holes for the bolts or lugs are much bigger on the new alloys than on the steels that are currently on the car!
I have looked everywhere and can only find people asking about the centre hole being too big, not the diameter of all the individual bolt holes. Does this matter? And if so, what can I do to fix the problem? Is there a spacer-nut I can get which will help fill the gap between the thread and the alloy?
The old steels slip on and off the bolts snug and the new wheels have much wider holes for the lug holds to go through.
Thanks for all or any help!
Dan.
Old Nov 28, 2016 | 08:55 AM
pcbp97's Avatar
pcbp97
You need to use the ford alloy wheel nuts. these incorporate a larger rotating collar.
Old Nov 28, 2016 | 09:23 AM
Daan's Avatar
Daan
Cheers for the fast reply!
I assume these just 'fill' the wider holes by having a bigger collar to clamp to wheel onto the car?
Is this a normal thing then that alloys have larger holes than steels and therefore require different nuts?
I suppose as long as the hub fits tight into the wheel then its alright?
Thanks! Panic over...?
Old Nov 28, 2016 | 09:33 AM
Cossy Mike's Avatar
Cossy Mike
Wheel nuts for steel wheels are different to alloy wheel nuts
Standard Ford size is M12 x 1.5 pitch, normally Ł1 a nut
Old Nov 28, 2016 | 09:35 AM
fatboy billy's Avatar
fatboy billy
Yeah alloy wheels have the spinning colllars on the wheel nuts hence he bigger hole with them nutsbyhe wheels will fit straight on
Old Nov 28, 2016 | 10:20 AM
Daan's Avatar
Daan
Cheers for all the help guys, I feel a bit silly 😂
These seem as if they would be correct - bearing in mind the car is a fiesta and the wheels are focus.
http://www.ebay.co.uk/itm/230898615591
Old Nov 28, 2016 | 11:22 AM
pcbp97's Avatar
pcbp97
I would use these on ebay item 201569195596. The ones you posted don't have the rotating washer.
Old Nov 28, 2016 | 12:10 PM
Rowe's Avatar
Rowe
Skint
a rotating collar isn't a necessity
Old Nov 28, 2016 | 12:32 PM
Daan's Avatar
Daan
Hi Guys,
I guess it isn't a necessity but its better to have one.
They're the best ones I can find too - only issue is there is only 1 left in stock!
I'll message the seller and keep looking in the meantime!
Cheers again
Old Nov 28, 2016 | 02:56 PM
Daan's Avatar
Daan
Hi Guys,
I cant find any other nuts that are open ended with a washer.
Does anyone know of anywhere that will sell them?
Could do with some by the weekend
Thanks again
Old Nov 28, 2016 | 03:44 PM
gcfcos's Avatar
gcfcos
Ford still sell the ones with spinning washer, bought a set a few months ago for my saph
Old Nov 28, 2016 | 03:47 PM
RichieST's Avatar
RichieST
Just get yourself a used set on eBay, with locking wheel nuts. Usually plenty on there.
Cossy Mike's Avatar
Cossy Mike
Originally Posted by Daan
Hi Guys,
Thanks again
I don't have collar washers on any of my wheel nuts, I got mine from JJC race and rally Ł1 each free delivery.
Old Nov 28, 2016 | 03:49 PM
RichieST's Avatar
RichieST
http://www.ebay.co.uk/itm/122183501591
Something like this for example!
Old Nov 28, 2016 | 06:01 PM
Daan's Avatar
Daan
I have ordered some genuine nuts from Ebay! Thanks for all the suggestions!
One last question if I may...
When I temporarily fitted the new alloy wheel on the rear of the car it rubbed ever so slightly on the flexible lining of the inner/rear of the back arch. I could simply hold the lining out of the way with my hand but was wondering what I should do when I come to fit the wheels, do I need spacers or do I just push the lining back and hope it holds?
The lining is loose and almost feels baggy
Thanks
Old Nov 29, 2016 | 09:14 AM
Rowe's Avatar
Rowe
Skint
what wheels/tyres are you planning on fitting? and to what car?
any signs of contact inside the arch will be an MOT failure unfortunately.
Old Nov 29, 2016 | 03:13 PM
Daan's Avatar
Daan
Hi,
Its an 07 Fiesta MK6
Fitting Focus ST170 Wheels
It isn't like it would grind - just like loose material resting on the wheel.
Is the only reason for spacers to set the wheels out so they don't grind/drag?
Old Nov 29, 2016 | 06:32 PM
RichieST's Avatar
RichieST
Are all the clips for the arch liners there? Is the car lowered at all? Where is it catching? On the inside when on full lock or all the time?
Old Nov 29, 2016 | 10:02 PM
Daan's Avatar
Daan
I've only fitted a rear wheel now just as a test.
It was rubbing on the inside rear of the wheel. All clips should be in place, i haven't removed linings. I will check later in the week.
The car isn't lowered.
I'll vheck a front wheel in the week too, see how that fits. Hopefully my nuts will have come in a day or two so i will get back to you.
Ps. Does anybody have a good method of removing corrosion from the back of alloys?
Thanks gents!
Old Nov 30, 2016 | 09:43 AM
_Jimmy_'s Avatar
_Jimmy_
I would have thought they'd fit ok. ST150 wheels are 17x7Jx47 offset so not too different to the ST170 ones. If the tyre profile is too wide and/or tall that might be the problem.
If not, it's pretty easy to fit rear axle spacers up to 25mm thick, or you could use hubcentric spacers.
If you mean the corrosion on the mating face, give it a light rub over with a bit of wet and dry sandpaper to make it smooth/flat. A light smear of copper grease onto the mating surface before fitting will help reduce corrosion.
Old Nov 30, 2016 | 10:14 PM
Daan's Avatar
Daan
Hi,
Today my nuts arrived so I decided to take a more in depth look at the wheel clearances and fit.
As you can see, the rear wheel is 'dragging' against the inside material but is barely touching with any pressure - the other rear wheel (havent fitted yet) doesnt seem to have such a baggy material wall - I'm guessing this will be fine, might just have to hold the material back somehow.
The nuts look great so thanks for the help!
The front DS wheel is good, it is positioned below the spring however, is this a problem? And when on full lock left, if presses against a plastic in the arch on the front, will test to see if the standard steels do this tomorrow!
The HUB of the car only comes through the alloy a couple of millimeters, should it come through more or is this okay?
PS. On the topic of the rear of the wheel removing corrosion, I mean the inside rim of the wheel, not the mating face - its just a bit bubbly (the paint)
Thanks!
I wi
Front Drivers Side Straight Lock
Front Drivers Side Full Left Lock
Rear Drivers Side
Rear Drivers Side 2
Rear Drivers Side 3
Hub Through Alloy
