Ford Focus Diesel This forum is for discussion of all things pertaining to the Ford Focus Diesel Range.
TDCi Focus - limp mode now won't start
Old Oct 16, 2016 | 08:18 AM
splash550's Avatar
splash550
Default TDCi Focus - limp mode now won't start
My TDCI Focus went into limp mode and now won't start - turns over but dies and won't run.
Similar symptoms happened three years ago and it was a split turbo pipe, but not this time - I've checked.
Planning on get a garage to read the fault codes tomorrow, but until then, any ideas folks? Thanks in advance.
Old Oct 16, 2016 | 08:22 AM
RichieST's Avatar
RichieST
Could be anything, from a sensor to a fuel pump, or even one of the cam belts (the lower one often gets neglected). Get the codes read and go from there.
Old Oct 21, 2016 | 06:14 AM
splash550's Avatar
splash550
Outcome: Fault code pointed to slightly low fuel pressure from pump. However, when reset the car started and ran fine, and has been doing for the past 3 days without throwing up any more fault codes. Car had had lots of short journeys and looks like it threw a wobbly because of it. I had fuel filter changed on advice. Cheers.
Old Oct 21, 2016 | 06:38 AM
splash550's Avatar
splash550
To add, they also did a leak test on injectors and all was as should be.
richardindorset
Ford Focus Diesel
Oct 20, 2016 08:45 PM
Robmatheson
Sep 4, 2016 09:25 PM
siscossie
Sep 1, 2016 05:50 PM
nick46
Aug 31, 2016 05:47 PM
rsp36
Aug 3, 2016 08:56 PM
