Firewall flex around steering rack
Old Aug 16, 2016 | 09:24 AM
JesseT's Avatar
JesseT
Default Firewall flex around steering rack
I just noticed (car stationary) that the whole firewall flexes amazingly much around the steering rack mounting area when torque is exerted on the steering wheel. There's at least 6mm of movement left/right on the steering rack when the wheel is rotated CW/CCW, and before somebody asks, I see none of that coming from the rack bushes. On all newer cars the rack is attached to the same subframe as the track control arms, which is a far superior solution...
But, my question is, has anybody actually done anything to improve the rack/firewall rigidity?
Old Aug 16, 2016 | 11:35 AM
_Jimmy_'s Avatar
_Jimmy_
Some cars have brake master cylinder support brackets for the same reason
I'd imagine you could get some form of bracing fabricated to support it, it's probably not going to flex anywhere near as much with the car rolling forward
Old Aug 16, 2016 | 03:49 PM
matthart's Avatar
matthart
The cabriolet had a support bar from the steering column frame to the A pillar. I've got one on my Orion and it makes the whole thing rock solid, definitely worth getting one.
Looks like this
Old Aug 16, 2016 | 07:31 PM
haz87's Avatar
haz87
Looks like this
Where on the a-pillar does this go? Ive got one to fit, but the dash is in and like feck can i see or find a locating/bolt hole. Realise dash out would be easier but was hoping to get away being lazy...
Old Aug 16, 2016 | 09:25 PM
matthart's Avatar
matthart
Sorry mate, it's a dash-out job because you need to get a spanner into the A pillar to hold the nut/bolt to tighten it.
Can't remember the exact position but once you pinch the "fork" end onto the column, it pretty much only goes in 1 way.
Found this picture for a LHD model
Old Aug 21, 2016 | 04:30 PM
Micky's Avatar
Micky
You learn something new everyday!!
Old Aug 22, 2016 | 09:22 AM
JesseT's Avatar
JesseT
So it seams nobody has done anything to strengthen the rack mounting, only column supports.
Old Oct 13, 2016 | 09:07 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Bit late.. I have mods for rack brackets which heighten and tighten. Then have twin support bars for master cylinder and also steering column.
Old Oct 13, 2016 | 07:22 PM
zippyobrien's Avatar
zippyobrien
Are these something that can be used on a fiesta Rs turbo. Doing some rust repairs to mine, and would like to strengthen it if I can
JohnRamo98
Wheels and Tyres
May 3, 2016 06:08 PM
A.t.p
Apr 29, 2016 11:50 AM
manuel boeckx
Apr 10, 2016 12:35 PM
adam151082
Feb 26, 2016 12:09 PM
3dr cossie
Dec 8, 2003 06:57 PM
