ST170 Camshaft Specs
Old Jul 27, 2016 | 12:21 PM
Tigercatkid's Avatar
Tigercatkid
Default ST170 Camshaft Specs
Hi,
just wondering if anyone has the timing and valve lift specs for the stock ST170 camshafts? I'm trying to calculate whether I will need to have my pistons pocketed when changing over to a higher-lift racing cam...
Cheers...
Old Sep 16, 2016 | 08:51 AM
pyle's Avatar
pyle
O.E.M. Cam
duration 277 / 265
duration 230 / 220
maximum lift 10.95 / 9.85mm
lift at TDC 0.25 / 1.05mm
Not sure if it's correct, its from CFM's site.
Old Sep 16, 2016 | 08:55 AM
Tigercatkid
Thanks - thats very helpful
Old Sep 16, 2016 | 10:47 AM
STeve's Avatar
Super Moderator
had these cams recently installed along with a few other mods and was very happy
http://www.burtonpower.com/kent-cams...kcst1703x.html
Old Sep 16, 2016 | 11:03 AM
Tigercatkid
Hi, thanks for the reccommend... I was looking at the Piper270 cams they have slightly lower lift.
Did you have to pocket the piston crowns, or was there sufficient clearance ?
any idea of the power / torque gains ??
Old Sep 16, 2016 | 12:07 PM
STeve's Avatar
Super Moderator
dyno'd at 205 but thats with combination of other mods too, no piston work needed but I did buy entire kit inc followers etc tuner said the cams were prob worth around 12 ish extra hp
Old Sep 16, 2016 | 07:01 PM
pyle's Avatar
pyle
Those are huuge cams. These are for 280+ cams!!
vanquish Fire
25
Jan 30, 2020 04:45 PM
burnzy
Jun 17, 2016 06:32 PM
Pitbull69
Jun 12, 2016 10:09 AM
Pitbull69
May 22, 2016 02:49 PM
oilman
Trader Parts for Sale.
May 12, 2016 09:11 AM
