cometic gaskets
Old Apr 7, 2005 | 07:29 PM
mcgoo's Avatar
mcgoo
Default cometic gaskets
this might sound like a bone question but i know cometic gaskets are reusable but i assume the head gaskets are not, am i right or are they, reason i ask is just fitted one, mating faces perfectly clean, new bolts and tightening sequence followed and its took a lot of water and i think theres water in the oil!
Old Apr 7, 2005 | 07:45 PM
pugo's Avatar
pugo
they are supposed to be re-usable, but i have never known anybody actually try...........they are only £130 odd, why take the risk
Old Apr 8, 2005 | 09:04 AM
Stu @ M Developments's Avatar
PassionFords Creator
Cometic do NOT advocate re-using their head gaskets.
Old Apr 8, 2005 | 05:53 PM
mcgoo's Avatar
mcgoo
thats what i thought, well pi**ed off now, it's only an 18000 mile engine and both surfaces were spotless, i don't understand what has gone wrong, ho-hum back to the garage to strip the fuc*er again!
Old Apr 8, 2005 | 07:11 PM
Niall.b's Avatar
Niall.b
Poss the wrong gasket allowing water/oil ways to leak into each other??????????
Old Apr 9, 2005 | 10:20 PM
mcgoo's Avatar
mcgoo
on closer inspection i was completely wrong, the water feed pipe had a minute split in it and this explained the loss of water, the water i thought was in oil is in fact fuel, i took all the plugs out and no 1 was black, i think no 1 injector is stuck open which would also explain why its used 7 quids worth of fuel for 25 mins running at idle, a bonus in some respects, i'd rather replace an injector than pull the engine apart again!, thanks for your input guys!!
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
Brickhouse
Sep 23, 2015 06:28 AM
pie-face
Sep 15, 2015 10:43 AM
