st 170 headlight leveling issues
Old Apr 11, 2016 | 07:05 PM
dirtysteve's Avatar
dirtysteve
Default st 170 headlight leveling issues
hi all, i recently lowered my 170 by 30mm, but this has upset the auto leveling on my zenon headlights, the switch arm on the wishbones keep popping off, thinking about it now i probably should have shortened the arms by the 30mm i lowered the car by, has anyone had experience with this?, cheers, steve
Old Apr 11, 2016 | 09:05 PM
RichieST's Avatar
RichieST
Did you take off the levelling sensor when you took the strut off? If so make sure it is refitted the right way around. I had this issue with my mk2 st.
Old Apr 14, 2016 | 06:09 AM
STeve's Avatar
Super Moderator
mines 25 lower on eibachs and it did not effect it, just check it out as richie mentioned
Indyrs
Apr 7, 2016 09:53 PM
Kris84
Apr 7, 2016 07:19 PM
A.t.p
Apr 3, 2016 09:49 PM
cossiestu
Mar 23, 2016 09:24 AM
21
Mar 13, 2016 08:39 PM
