head bolts
Old Apr 7, 2005 | 03:40 PM
jakki's Avatar
jakki
Default head bolts
just wondering whats the best route 2 go....my cars running a t34 hybrid, light blues, rs500 intercooler, rad n turbo cooler, heads been ported n polished, bd10 cams etc n ave just been gettin a extra thick head gasket cos the heads been skimmed on my car.........but what head bolts do i use?
should i get uprated ones or r standard ones ok for running hi n low boost...hi bein round bout 23psi
just dnt fancy gettin standard ones n them stretching n knacking the gasket...
cheers
Old Apr 7, 2005 | 08:01 PM
supatune's Avatar
supatune
standard bolts are fine my bosses cossie is running 410 brake with a cometic gasket and the bolts are on their second time round they dont stretch twice!
Old Apr 7, 2005 | 08:06 PM
pugo's Avatar
pugo
stud and nut kit from arp
Old Apr 8, 2005 | 02:50 PM
Rs1's Avatar
Rs1
I agree a stud and nut kit. This can be reused over and over as there is no stretch/angle to to do when torqing up.Gives a much better(more even)clamping force.
Make sure the block and head are spotless if your going with a steel gasket as they are much less forgiving with any imperfections on the mating surfaces.
Old Apr 8, 2005 | 02:53 PM
cozzycol's Avatar
cozzycol
Jakki i used arp stud and nut kit and had probs with head gaskets leaking, went back to std bolts and they are fine, mine running same spec as yours
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 19, 2015 08:27 PM
hopper350
Sep 4, 2015 12:53 AM
