Using a rotary for the first time- Advice please!
Old Mar 7, 2016 | 10:08 PM
mjonathan24's Avatar
mjonathan24
Smile Using a rotary for the first time- Advice please!
Hello, Ive recently bought a rotary polisher and will be doing a spot of light correction work on my saph cosworth.
Now, I've used a DA loads of times with some good results but I know these can be achieved quicker with a rotary.
Any tips?
I was thinking that I would make light quick passes with a fairly wet sponge pad and some g3 and then use a refining polish to finish? Does anyone have a lot of experience with one?
Old Mar 7, 2016 | 10:27 PM
tony66's Avatar
tony66
Default rotary
i make sure i have a water spray to keep the panel wet
i"ve been told g3 is the caveman choice now-although i still use it
i think for classics etc there are far better choices now,nicer waffle pads etc
i"m no detailer at all but g3 revives paint well,but very course
Old Mar 8, 2016 | 06:15 AM
AJC's Avatar
AJC
Plenty of threads on detailing world to read, try them
Old Mar 8, 2016 | 09:02 PM
JasonPD's Avatar
JasonPD
I'd be suprised if you need a rotary on saff paint, the paint on my car is so super soft the da will cut it in no time. Detailing World will give you step by step advice and tips so I'd suggest you head over there.
Old Mar 12, 2016 | 02:45 PM
Retro Al's Avatar
Retro Al
RWD IS KING
A good DA + microfiber pads cut well enough on any paint, since I got my rupes my flex hardly gets used,you can go through paint just as easy with da its all about knowing the paint condtion your dealing with,you would be better off spending money on a PTG and keep the DA imo
Old Mar 12, 2016 | 03:18 PM
mjonathan24
I am just going to be very careful with it, hopefully soon I will have a ptg and can really see what results I can achieve with a combination of the rotary, da and by hand.
Old Mar 12, 2016 | 03:22 PM
Caddyshack's Avatar
Caddyshack
10 Year Member
I use the 3m range of fine, super fine and fast cut with the colour coded pads, I use the da though as my rotary can be very harsh and I have burned through paint with it before. I only use the rotary for metal cleaning now.
Old Feb 23, 2019 | 08:53 AM
ted11's Avatar
ted11
restorer
If you have not had any previous experience with a rotary polisher, do not use it on your pride and joy, many people do try and some get great results but the more confident you get with the rotary, the more chance that you will push your lock to far and break through, stick with the DA.
Carlos-Titx
Insurance
Mar 8, 2016 09:43 PM
povey@pembrokeshire
Mar 8, 2016 05:27 PM
lockie
Mar 7, 2016 05:02 PM
JoeyBoyden
Mar 7, 2016 04:54 PM
fordsteve77
Escort MK 5 / MK 6
Feb 13, 2016 08:47 AM
