Offset/spacing wheel help!!!
On a tangent
Right my offset is ET 35..wheels I want are ET 38...
So am I right that 3mm spacer will do job without needing longer studs??
Trouble is I cant find 3mm spacer only 5mm, so will I need to get longer studs??
Foooooking help
Cheers lads
Foooooking help
Cheers lads
On a tangent
Loads of 3mm spacer shims on ebay.
I've always been a bit wary of shim style spacers as I don't like the idea of recuding the spigots width. However, you'll need to go at least 10mm to get hubcentric.
On a tangent
Wotcha reckons best to do fella..?
They are the only wheel I like, and I don't wanna bodge em on
On a tangent
Take ET35 wheels to machine shop.
Get 3mm machined off faces and voila ET38.
As for safety its probably not a great idea to start machining bits off wheels
Best thing to do is buy some ET38 wheels..
On a tangent
This makes no sense to me lol are you say machine down from 38 to the 35 I NEED?
I cant find anything in 35... They is all shit fuck ugly ffs lol
Yes you can just buy ET38 stick a 3mm spacer on to bring back to ET35 and jobs a carrot. running a 3mm spacer is probably ok with original studs or if a little short get longer ones.
Sorry for confusion I thought you already had ET35 wheels and wanted to make them ET38..
On a tangent
Cheers Dave, these are alot wider than standard..
They are. 16x7.5. 4x108 ET38. 76mm centre bore.
Fitting them will be the only way then really. Iirc std rim is 6j, so your adding 38mm (ish) of width, taking that into account if my memory is correct the inner edge of your new rims will still be roughly 15mm closer to the suspension components ect.
Some manufacturers measure across the rim, some between the beads, so you may have a difference there too.
Dave
(std's are 5.5j, so it gets worse......)
Dave
