camshaft
Old Feb 28, 2016 | 07:07 AM
polle90's Avatar
polle90
Default camshaft
Hello, I have a kentcams cvh32 camshaft.
I know it is for na engine, but will it work in a rs turbo engine?
Regards, polle
Old Feb 28, 2016 | 08:04 AM
Chas's Avatar
Chas
Regards, polle
In theory any cam will work. But in this case it is not recommended since the N/A cams will have alot of overlap on them compared to a turbo camshaft, which will make your car suffer in driveability.
Old Feb 28, 2016 | 09:33 AM
Piston Broke's Avatar
Piston Broke
thought it was for a xr2i that cam ? wont be anygood in a turbo if im right.
Old Feb 28, 2016 | 02:02 PM
mattxr3i's Avatar
mattxr3i
Yes P B I think you are right, it was for the EFI CVH for the last of the XR3i MK4 and the MK3 XR2i 8V
Old Feb 29, 2016 | 01:10 PM
polle90's Avatar
polle90
OK thanks, I am not going to use it then.
Old Mar 2, 2016 | 08:14 AM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
If you're looking for a cam the only one I would recommend these days is from Newman Cam's.
Old Mar 3, 2016 | 10:43 PM
Chas's Avatar
Chas
I may have to do this despite a newish Piper Cam :'(.
Do Newmans only do solid lifter cams or can they do hydraulic items as well? I am aware that Solid lifters can bring about more accuracy with valve timing etc but I don't really want to be forever adjusting them, especially when there is pipework to remove on a CVH (yes, I am lazy!).
Old Mar 4, 2016 | 05:19 AM
haz87's Avatar
haz87
They did do a hydraulic - but it was worse than Kent/Piper/No cam at all (Wrote off an engine of mine ) - loads of people had issues and they stopped.
If done properly, the newman solids only require setting up once.
Old Mar 4, 2016 | 05:10 PM
gus's Avatar
gus
I now run a car cams jobbie
Hopefully all issues are now solved
Means a custom grind to own spec
Then had the cam and buckets dlc coated
So fingers crossed fit and forget
Old Mar 4, 2016 | 05:25 PM
RSmark84's Avatar
RSmark84
How long have Newmans Been doing Cams for the CVH? Ive known they've been doing them since roughly 2008 when I 1st heard about them. I ask because my S2 has an unknown 'high lift' cam as an ex mechanic of mine told me, Its packs a punch mid rev range, but low range its a tad 'lumpy'.
Old Mar 4, 2016 | 10:39 PM
Piston Broke
To be honest you can make good power on cheap cams now and they last well. As well as other more expensive cams if the engine is set up right. Solid is a good cam but a lot of dosh but set right do last well 😆
Old Mar 5, 2016 | 08:12 AM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
It's not about making power, it's about material quality and reliability, most cam's these days end up in bits in the sump taking out your engine along the way... the Newman is the only one I will fit and even then I've seen one fail a few years ago.
Old Mar 5, 2016 | 08:13 AM
haz87's Avatar
haz87
Agree with this totally. You'd be silly to believe Newmans are far from failsafe, but they are the best of a bad bunch
Old Mar 5, 2016 | 10:19 AM
gus's Avatar
gus
Stripped lobes off my Newman.
crappy material I think
Old Apr 11, 2016 | 08:13 PM
Piston Broke
Is there any truth in the 1.4 mfi cams (OE FORD) work in the rs turbos, think it may have been jano who said they were about the same camshaft on here moons ago
Old Apr 11, 2016 | 10:02 PM
steppy's Avatar
steppy
Reflecting what you've said, done around 8k on a newman cam and solid lifters they havn't needed adjusting yet
Old Apr 30, 2016 | 06:56 AM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Ford state this info in their own documentation i can show you.
Old Apr 30, 2016 | 09:17 PM
Piston Broke
Cool so it is true then. When I checked the spec on the parts listing and cross over there was no match but they work. What they like ? Just bought a job lot from Daventry cheap as chips 😊
Old May 1, 2016 | 01:01 PM
Adder's Avatar
Adder
I ran a N/A XR2 cam with my MFI turbo. Made reasonable power with stage one chip with no probs.
Adder
Old May 1, 2016 | 04:45 PM
mattxr3i's Avatar
mattxr3i
I thought RS turbo ran the XR3i cam, with a different pulley to retard the timing slightly. Probably wrong but sure I heard it from somewhere
Will Pedley Racing
Ford Focus RS Parts for Sale.
Jul 25, 2016 06:52 PM
COLEYST200
Mar 5, 2016 07:05 AM
bassboy
Feb 26, 2016 03:09 PM
adam151082
Feb 26, 2016 12:09 PM
iantwj27
Ford Focus Diesel
Feb 26, 2016 02:42 AM
