Mk6 fiesta clutch issue
Old Feb 27, 2016 | 04:50 PM
grass racer's Avatar
grass racer
Default Mk6 fiesta clutch issue
Just done a clutch change on my 07 mk6 fiesta Zetec s.
Bled the clutch went for a drive and hardly any clutch pedal pressure and almost no brake pressure. Very hard to get into 1st and reverse and crunches to get in those gears.
I know its got to be air in the brake system but ive bled the clutch more than enough just don't know how the clutch side of things isnt working as it should.
Tomorrow I'll fully bleed the brakes and clutch and hopefully this will sort it.
Anybody got any advice
Done a few of these mk6 clutches not had this problem before its annoying because it's actually on my own car! 😭
Old Feb 27, 2016 | 05:40 PM
stevos's Avatar
stevos
Did you change the slave cylinder as well mate?
Old Feb 27, 2016 | 05:46 PM
grass racer
yeah always do with these.
Always go with the LUK kit
Old Feb 28, 2016 | 11:02 AM
grass racer
Bled the system completely no air in brakes but there working as they were so fine now, clutch still the same hardly any pedal pressure.
Really have to push hard to get it in 1st or reverse still, reverse still crunches. not sure if cables are snagging on something.
Some white gunk came out as I bled the clutch now I'm worried and pi$$ed off if ive been given a faulty slave cylinder
Old Feb 28, 2016 | 03:08 PM
stevos's Avatar
stevos
I'm wondering if the slave is maybe faulty mate especially if you have bled it a few times.
Old Mar 7, 2016 | 04:23 PM
grass racer
box off again changed slave bled system again still no good!
Noticed one of the gear cables was wiggling around so ive cable tied into place and it now goes into gear when running but still crunches into reverse.
I am going to change the cable, but I don't understand why it's still crunching into reverse would the cables cause this?
Beanie439
Ford Focus (All Models)
12
Feb 12, 2016 04:23 PM
Neil S
Feb 9, 2016 06:29 AM
Eigdoog
Insurance
17
Feb 7, 2016 08:13 PM
everway9
Ford Fiesta
Feb 5, 2016 12:16 PM
fordsteve77
Escort MK 5 / MK 6
Jan 28, 2016 05:50 PM
