Am i being paranoid???????????
Old Apr 6, 2005 | 04:32 PM
smudgerz's Avatar
smudgerz
Default Am i being paranoid???????????
Ok, the problem is, my 2wd cossie seems to be runnig hot. The temp gauge reads ok but after a drive (not a hard thrash!!) when i lift the bonnet the engine is well hot. The water in the header tank is boiling and it smells like you have just been caining it for miles. Its had a new rad and hoses so maybe theres an air lock?
It maybe just me being paranoid and not wanting another massive repair bill.........
Cheers for any help and sorry for being a spaz!!
Smudge.
Old Apr 6, 2005 | 07:59 PM
dave cos4x4's Avatar
dave cos4x4
if the tem gauge sys its right then it might be right.
Has the water been mixed with summer coolant,this helps with the temps.
Dave.
Old Apr 6, 2005 | 08:08 PM
smudgerz's Avatar
smudgerz
Water has been mixed, more than likely just me being paranoid!!
Cheers for the reply Dave!!
Old Apr 6, 2005 | 08:20 PM
martinmace's Avatar
martinmace
run the engine at idle with the cap off the header tank , should allow any air leaks out, also put heaters on flat out. also if you can get the front of the car as high as you can that will help too.if it still gets hot and the water keeps boiling then i would start wondering if the head gasket is giving up asdave cos4x4, stated water being mixed that is a strong possibility. good luck mate
Old Apr 7, 2005 | 02:39 PM
smudgerz's Avatar
smudgerz
I had a nasty feeling it might be the head gasket on its last legs.........
Will try what you said Martin cheers mate.
Old Apr 8, 2005 | 09:05 AM
Stu @ M Developments's Avatar
PassionFords Creator
The Cosworth dashboard temperature gauge is very very very RARELY correct.
Most cars i get in are running over 100 degrees and teh gauge is less than half
Get it checked out before it melts down pal
Old Apr 8, 2005 | 12:16 PM
smudgerz's Avatar
smudgerz
Cheers Stu, looks like a trip back to Brom an see what he says.....bugger
Old Apr 8, 2005 | 07:12 PM
smudgerz's Avatar
smudgerz
Ment to add that its useing loads of water, around a lt a day. Think it might be a fooked water pump and or thermostat..... so will change both.
Old Apr 10, 2005 | 05:41 PM
smudgerz's Avatar
smudgerz
Just had it checked, water pump and thermostat are ok, the thing that is wrong is that the fans arnt working. The switch is fooked. So its all good!
Adam-M
Aug 26, 2015 05:53 PM
NoGutsNoGlory
Ford Escort RS Cosworth
69
May 12, 2008 05:47 PM
TemptRS
50
Apr 21, 2008 08:05 PM
haz87
Jun 2, 2007 12:20 PM
DAB
Mar 18, 2007 03:26 PM
