Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
Zetec S Heater Fan, Indicators, Electric Windows Stopped working
Old Jan 16, 2016 | 12:59 AM
p.laver's Avatar
p.laver
Default Zetec S Heater Fan, Indicators, Electric Windows Stopped working
My 2001MY Zetec has developed a strange Electrical fault.
Drove off everything was fine, went to use the indicators they had stopped working also the
heater fan
electric windows
Horn
All had stopped at the same time but the engine runs OK and all the electrical switches appear to work OK
All dash waning lights come on with ignition on, after starting engine they all go off in the normal sequence.
Started at the obvious, the fuses and they are all OK.
I'm not getting any feed to the heater switch etc. I'm thinking it might be the ignition switch. 4 wires on the back of the ignition, 3 have a feed. The 4th black with blue tracer no feed, is this right??
I can't seem to find an ignition switch diagram any idea?? or has anyone else had this problem and know the fix. Thanks
Old Feb 24, 2016 | 07:34 PM
zetec-s81's Avatar
zetec-s81
It's a relay behind the fuse box inside the car, take the pocket cover off and unscrew the two screws holding fusebox on and you'll see the black relays at the back its one of those
deathrider666
Dec 29, 2015 05:21 PM
Graham S1
Dec 24, 2015 04:18 PM
Ellsa
Dec 21, 2015 09:27 PM
BigBez
Ford Focus Diesel
Dec 20, 2015 05:28 PM
borboyous
Dec 18, 2015 05:57 PM
