Crystal Blue Saff recommision
Old Jan 11, 2016 | 10:45 PM
Jules44's Avatar
Jules44
10 Year Member
Default Crystal Blue Saff recommision
Managed to get some time to create my thread on the recommision of the Sapphire I bought in November, this is very new to me, always had mk1 escorts or modern diesels, so there will be loads of questions on the way.
All I am trying to do this year is get it roadworthy again after being sat in a garage for over ten years. then hopefully do more of a clean up next winter.
When I went to view it.
Having some issues uploading photo's at the moment, will try and add later.
Old Jan 11, 2016 | 10:51 PM
Jules44's Avatar
Jules44
10 Year Member
Old Jan 11, 2016 | 11:38 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Looks a great buy will make a good project
Old Jan 12, 2016 | 05:24 AM
155lee's Avatar
155lee
That's stunning,love standard crystal blue saphs.
Old Jan 12, 2016 | 07:00 AM
Jules44's Avatar
Jules44
10 Year Member
Changed the rear lights on the back.
To ambers
Old Jan 12, 2016 | 07:02 AM
Jules44's Avatar
Jules44
10 Year Member
Changed the fronts and removed the mesh from the fogs.
Old Jan 12, 2016 | 07:33 AM
Jules44's Avatar
Jules44
10 Year Member
Jacked up the front to change the tyres over and noticed the front spring was broken, so looked up front springs for Koni shocks and came across Ahmed Bayjoo at Grove Garage very nice to deal with.
New spring on
Old Jan 12, 2016 | 07:37 AM
Jules44's Avatar
Jules44
10 Year Member
Removed the clocks to swap the rev counter over as the original clocks the rev counter doesn't work.
Once the clocks were out I noticed the wiring for the radio is missing a block or something, anyone know which one the yellow one is for and does anyone have the connector for the other?
Old Jan 12, 2016 | 09:41 AM
gingeRS's Avatar
gingeRS
i thought all the crystal blue saffs were e plate
very nice, rare car
Old Jan 12, 2016 | 10:54 AM
Sierrasideways's Avatar
Sierrasideways
Great to see another being restored Ambers look great.
Old Jan 12, 2016 | 03:54 PM
Jules44's Avatar
Jules44
10 Year Member
very nice, rare car
Don't know but it was registered on the 1st August 1988
Old Jan 12, 2016 | 06:45 PM
eagie's Avatar
eagie
Very nice looks better with the ambers back on! I'm also restoring a saff that been off the road 10 years but it looks like it needs more than yours does
Old Jan 12, 2016 | 08:42 PM
fatboy billy's Avatar
fatboy billy
Nice project mate looks loads better with the ambers
Old Jan 12, 2016 | 08:59 PM
Zetec_mk4_XR3i's Avatar
Zetec_mk4_XR3i
Awesome car mate. That pic of the front corner with ambers back on is lush. Keep up the good work.
Old Jan 12, 2016 | 09:36 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Looks like a nice car mate! 
It's in the best colour as well but then I'm biased! Lol! 
Crystal blue is definitely much nicer on Amber lenses all round! 
Old Jan 12, 2016 | 09:47 PM
jason_nike's Avatar
jason_nike
very nice, rare car
They were on F plate too, but thats it
Old Jan 12, 2016 | 09:48 PM
jason_nike's Avatar
jason_nike
The car looks great now you have changed all the lights, very nice
Old Jan 13, 2016 | 05:06 PM
Top job matey. The ambers defo look better.
Old Jan 13, 2016 | 05:10 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
looks like a goodan!
Old Jan 13, 2016 | 08:46 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
Looks really nice
Old Jan 13, 2016 | 09:12 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Very nice best of luck with it mate.
Old Jan 13, 2016 | 10:32 PM
Roscopeco's Avatar
Roscopeco
P8 Managed S1 with ALS
Always wanted a crystal blue saph , has to be my favourite saph colour . Looks a nice project
Old Apr 13, 2016 | 10:30 PM
Jules44's Avatar
Jules44
10 Year Member
Bit of an update.
Front brakes have been rebuilt with new seals pistons and new pads.
Rear Brakes new pads fitted.
Front Koni shocks rebuilt by SP Suspension and fitted.
Front springs replaced with Ahmed Bayjoo springs.
Rear Koni shocks tested all good and fitted.
All brake fluid replaced.
Engine.
Timing belt replaced.
Alternator belts replaced
Power steering belt replaced.
Water pump gasket replaced
New 82 degree stat fitted and new gasket fitted.
Air filter removed and refitted airbox with new k&n filter
Oil & oil filter replaced
New Airtec rad fitted
Radiator fan wiring upgraded fitted
New dizzy cap and rotor arm fitted
ICSV cleaned out.
New fuel filter fitted, unable to fit upgraded wiring loom as unable to open doors fully due to storage container.
Hopefully this weekend I will be replacing all fluids and fresh petrol and attempt to start it, fingers crossed.
Any pointers of starting up an engine that has not been started in ten years.
Old Apr 14, 2016 | 09:45 AM
Farmer Giles's Avatar
Farmer Giles
personally I'd make sure it turns over by hand first then once I've wound it round a couple of times I would disconnect the coil then wind it round on the starter to get the oil pressure up then once that's done try and start it..
if it's been stood that long then there could be sensors that have corroded or broken down, injectors could be stuck etc etc. the list of possible problems could be quite long..
good luck
Old Apr 14, 2016 | 04:17 PM
Jules44's Avatar
Jules44
10 Year Member
good luck
Cheers it definitely turns over by hand, as I put some light oil down the bores first before I even attempted to replace the timing belt.
I'll make a note of the oil pressure light with the coil disconnected, let's hope nothing is corroded or broken down but I suppose that's what happens with a 28 year old car
Old Apr 17, 2016 | 06:57 PM
Jules44's Avatar
Jules44
10 Year Member
Tried to start it today, but it wouldn't start, it turns over okay, tested spark all good, I'm thinking its fuel related possibly pump, how would you test this?
When you turn the ignition on the pump doesn't make a noise and if you put your hand on the pump you can feel a little movement and when you crank the engine over you can feel movement but it is silent are they supposed to make a noise?
Old Apr 17, 2016 | 07:55 PM
yawiejon's Avatar
yawiejon
Took mine out for a blast to a track day event, looking forward to the ford shows this year
Old Apr 17, 2016 | 08:41 PM
stevos's Avatar
stevos
Not a cossie man mate but from some posts I have read I'm sure there is a relay in the boot for the pump this could be worth a look also.but may be wrong.
You should hear a fuel pump prime. Everything I drive I can hear it prime.
Try giving it a light tap with a persuading device also.
Old Jul 5, 2016 | 09:59 PM
Jules44's Avatar
Jules44
10 Year Member
Replaced fuel pump and new petrol tank, all cooper washers etc, now car is all running and mot'd straight through with no advisories which was a bonus, now taxed and have currently done about 300 happy miles.
A few problems I am having is that I think it is overfuelling as the plugs are all sooty, and it is really fumey in the car after a while, I have put tape on the vents in the boot but its still fumey, anyone had similar experiences???
Old Jul 6, 2016 | 04:15 PM
stevos's Avatar
stevos
Best to get the car set up on a set of rollers at a reputable company mate like msd or the likes. Could be a faulty fuel pressure regulator but they guys will be able to suss out your problem. It's really not worth messing around with yourself.
Old Jul 6, 2016 | 05:30 PM
visa_broke's Avatar
visa_broke
10 Year Member
needs more pictures especially with the ambers
Old Jul 6, 2016 | 08:30 PM
Jules44's Avatar
Jules44
10 Year Member
Old Jul 6, 2016 | 09:15 PM
goodison1972's Avatar
goodison1972
nice!!
Old Jul 6, 2016 | 09:42 PM
Adam-M's Avatar
Adam-M
Looks gleaming nice find
Old Jul 7, 2016 | 12:32 AM
gcfcos's Avatar
gcfcos
Stunning looking car mate. Would defo go and have it set up somewhere that knows what their doing. What part of the country do u live in?
Old Jul 7, 2016 | 04:55 AM
Cossiemainful's Avatar
Cossiemainful
can't beat a nice looking crystal blue one with ambers
Old Jul 7, 2016 | 11:17 AM
Jules44's Avatar
Jules44
10 Year Member
Near Leicester
Old Dec 5, 2017 | 08:39 AM
Jules44's Avatar
Jules44
10 Year Member
Not updated this for a while, for to busy enjoying it and sorting out the little niggly bits as they evolve
2017 National day.
Notts show
Old Dec 5, 2017 | 08:44 AM
Jules44's Avatar
Jules44
10 Year Member
Been losing quite a bit of oil since it has been on the road, so decided to tear it down and replace all gaskets and seals etc. The only thing I have painted is the block and water pump, would love to go down the mint route but where do you stop getting carried away and afraid to drive it.
Old Dec 5, 2017 | 08:54 AM
Jules44's Avatar
Jules44
10 Year Member
Spent about two days and a couple of evenings cleaning it all up of old oil and dirt build up.
