Trying to get the ZT engine running while I'm off over Christmas, Got the keys sorted out for the immobiliser, red LED and the fuel pump priming tells me it ok, fuel is getting to the rail ok.
No spark at plugs when I test them to earth, I have power at the coil pack (middle pin) but don't seem to get anything at the other 2 pins for cyls 1&4 and 2&3.
Self wired to Omex ECU, does anybody have the test procedures for the position sensors that feed the ECU for it to send the signals to the coil pack.
Is there anything else I could test?
You need the tuning software on a laptop and connect the lap top to the ecu. The last two I did both needed a serial adapted and these being Chinese can be very hit and miss on if they work or not.
Once powered up you will see the base map and all the engine sensors. You can set the tps and you will see the engine cranking with a tachometer signal.
The two options for crank sensor you commented on are Vr and hall affect.
The zetec uses the Vr sensor they are polarity sensitive.
