2wd water temp gauge not working
Old Dec 16, 2015 | 08:30 PM
jc1989rs's Avatar
jc1989rs
Default 2wd water temp gauge not working
Hi all
I changed the oil pump due to the pressure dropping all is good with that but now but the coolant temp gauge has died during this! The sensors good I know that but there's no power to it. On the wiring diagram it shows it's a direct feed from the instrument cluster and I'm guessing that's where it gets it live from to?
Cheers all JC
Old Dec 17, 2015 | 07:36 PM
jc1989rs's Avatar
jc1989rs
Anyone?
Old Dec 17, 2015 | 07:39 PM
martysmartie's Avatar
martysmartie
It's the earth, but yes you should see power here, I assume you did check this with the ignition on?
Has the cable got pulled etc when you lifted the engine?
Martin
Old Dec 17, 2015 | 07:57 PM
jc1989rs's Avatar
jc1989rs
Cant be the earth as its earthed through the head and there's a soil Earth on that. I shorted out the wire to earth and the gauge didn't move at all to. Yup all checked done with ignition on.
I re ran the wire round the front by the intercooler before the engine was lifted but it's a possibility, trying to avoid chasing it through the loom but I think that's the only other option now.
Old Dec 17, 2015 | 08:44 PM
martysmartie
The wire your talking about is the earth for the gauge and it connects to the cluster, it will be the exposed part if anything. You won't be able to trace it back any further as it will be part of the loom. Is the connector clean etc?
Martin
Old Dec 18, 2015 | 08:21 AM
jc1989rs's Avatar
jc1989rs
ah ok I get you. yes connectors all clean have spliced a replaced a small section as someone had bodged it. Do you think it could be the gauge?
Old Dec 18, 2015 | 04:07 PM
martysmartie
Check first if power is present before your repair.
Martin
Old Dec 18, 2015 | 04:59 PM
Cossy Mike's Avatar
Cossy Mike
Mine stopped working and it turned out to be the gauge itself but on this occasion I would say youve disturbed the wiring somewhere.
It's only one wire so should be easy to trace
Old Dec 20, 2015 | 08:48 PM
jc1989rs's Avatar
jc1989rs
Cheers for the help chaps. Traced it back today and the cable had a break in it past the injectors in the plastic conduit. All working now
Old Dec 23, 2015 | 11:05 AM
martysmartie
Thought as much, glad it's sorted.
Martin
Willka
41
May 3, 2019 01:35 PM
Rs Gus
Dec 23, 2015 12:55 PM
Bailes1992
Dec 14, 2015 06:25 PM
Adam-M
Dec 13, 2015 07:31 PM
admiral
12
Dec 13, 2015 06:28 PM
