How many volts should this little SUPRESSOR take...
Ok chaps pictured below is the radio suppressor
Bosch part no. 0 119 910 002 - ford no. 86GB17K499AA
At the INLET wire to this is 12.15 - 12.30 ish Volts reading on multimeter...
On the outlet of suppressor going to the wiring loom which ends up at Speed Sensing Module is 1.60 Volts
Is this normal procedure to take it from 12.30 Volts DOWN to 1.60 Volts...?
And if not what voltage does the Speed Sensing Module need to activate/work
1st photo is Suppressor - 2nd is Speed Sensing Module
I'm no auto electrician but the speed sensing module has a 12v badge on it. Now I'm sure the way a modern car takes it speed readings from the abs sensors and it reads resistance in ohms as I'm sure that's how you check if an abs sensor is faulty. But anyway this isn't helping you out but maybe your speed sensor will work in the same way and although it has a 12v supply maybe the speed is determined by resistance if that makes any sense as I said I'm no expert and may be wrong on all accounts.
http://www.rhocar.org/index.php?showtopic=380
If it is what they say it is, a capacitor in a box then these can break down and fail after a while which would fit your symptoms.
To stevos, its on an XR3i MFi 1988
When I disconnected it and plugged the 2 ends together the car started and ran and the voltage was 13.50 all the time the car was running, which was only 5 mins...?
What voltage should the outlet of the suppressor be around the 12 volt mark...?
It didn't run fine is was lumpy running 'BUT' it ran, but only for about 4-5 mins then cut out...
I have been having starting problems, well it starts over then cuts out after 2 seconds..
But every time I bypass this suppressor it will not run, say out of 10 times ive tried about twice it will run but again only for 4-5 mins then die,
I have severval other posts on here regarding other parts that make up to start/run system on me XR3i, just trying to pin point through the lot
so the alternating current sends pulses to the speed sensing module ( bosch call it electronic control module see pic) then on from that to the tach.... so if the radio suppressor or ignition module or speed sensing unit are foocked or all 3 this would cause no tach working and running problems...?
If I am not mistaken, wasn't that little black box meant to be used to alter the voltage for the coil when starting as some coils ran @ 9v when starting and 12v when cranking (or the other way round). Gave more power for starting the car or something similar.
It has been a while and my mind is a little foggy.
I will have a look in a ford wiring manual I have somewhere to check.
But, from what little I can remember! The ignition coil flyback is routed to the tach via a green wire, I didn't know that it also went to the speed sensing module (but it makes sense) to provide one or both of the ecu's with an RPM pickup.
What is in the chain first? Ie what is closest to the ignition amp/coil, the radio suppressor?
http://vwts.ru/injector/k_and_ke-jetronic.pdf
After a quick read of that, I think they also refer to the speed sensing module as a safety module.
Does your fuel pump run when you first turn the key and when you are cranking the engine. It looks like the speed sensing module is used to disable the fuel pump relay if the engine stalls.
It primes with igniton on I can hear it,
then go to start fires up for 1 -2 seconds primed fuel runs out it stalls
But other day when I bypassed the radio suppressor it ran for 3-5 mins very lumpy could not accelerate with the pedal or it would go to die then it cut out and could not strat agin only for th 1-2 seconds after priming
Those pictures don't really help
1) check to see if you have spark.
----If you do not then nothing else will work as the high voltage flyback mentioned in your pictures as "pulses from terminal 1 of ignition coil" will not be present.
2) If you have spark then the ignition amp is ok, so move on to the next part in the chain, (radio suppressor?)
3) with the radio suppressor removed and shorted perform a continuity check from the coil term 1 to the back of the tach and then from coil term 1 to speed sensing module.
Tell us what you find.
Purchased at the end of September
was running and driving started all the time
there was no Fuel Pump relay present
there was a ignition live to where the fuel pump should go
I removed that and the dodgy Moss alarm there was no immobilser
I changed everything above and fuel filter and oil change
then this started
then this started
No worries mate, the more info the better
Was the tacho working when you bought the car? I'll have to do a bit more reading, the book I have is for the RS Turbo which apparently?!?! Has a different ignition system to the XR3i... I've never owned an xr3i so am working partly on assumption. The good news is that the XR3i ignition system looks much simpler than the RS Turbo!
Still 100% check for good spark to begin with. If the tacho was working when you bought the car it sounds as if the engine speed module may have a big part in this if the original fuel relay was bridged out like that.
It's same ignition system as a mk2 xr2. I've had the same fault quite a few time in my time Bing in the trade and it's all ways been the ingnition module. That cause all sorts of problems. Hence why the pump relay is not kicking in when he is cranking.
Got an ignition module/amp and radio suppressor both coming today/tomorrow
Brand new at a cost of Ł21 all in so not bad for piece of mind
And too Rob no the tacho was not working either when I purchased, bought it to restore it back to its former glory... weren't expecting to be taking the dash out and chasing wires the engine itself it in mint condition, apart from this electrical problem, just want it running so I can drive it to paint shop
Could well be mate. But a faulty ignition amp means no spark. no spark means no flyback voltage to trigger the tacho or other modules looking for the 'pulse'. Either way the no spark or a very weak spark is easy to check for and would certainly point to the ignition amp as a suspect.
Correct, just a quick reality check to make sure the tacho wire is not shorted to earth somewhere. Set the multimeter to 2000 NOT 2000K as that is actually 2000 000 (2M).
Ignition off and on the tacho side of the suppressor (ie the side going to the car not the side going to the ignition coil). I am assuming this will be a fairly high value however if it is not it might help you to isolate an issue.
BUT - if you do have spark I suspect the issue may be the suppressor.....
If you do not have spark the issue is likely the ignition amplifier.
Does the car run if you short out the fuel pump relay like it was when you bought it?
https://www.clubford.ro/documente/ma...01981-1990.pdf
Page 226 is your diagram. Assuming your is after 1986:
Part 138 is the suppressor
Part 133 is the speed sensor relay/module
Part 68 is the Fuel injection relay
Part 102 is the instrument clustor (tacho)
It looks like the speed sensing relay uses the flyback from the negative of the ignition coil to enable the fuel injection relay. The flyback voltage signal goes via the suppressor to the speed sensing relay.
Rob,
Rob,
If you have spark I would just wait until your suppressor turns up and give that a go. If no spark then exchange the ignition amp and go from there. Good luck! Looks like a good project too btw.
Rob,
did you ever test the continuity of the green wire from the fuel relay to the coil?
although it does look like a component issue as it runs with the suppressor linked out,
on a side note a m8 has a complete mk4 cabby hes breaking if you need any little bits for yours, hes keeping all the running gear etc but theres a set of clocks in it plus some panles and trim, only in iwade so local
