General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi do you's think this arrow is the direction of what way it goes in? Normally they are on top of the Pistons and are directed to timing belt but this am assuming Point to front of engine?
You're going to have to put a 90 degree twist in the rods to get that arrow to point forward.
Its fwd,
The only difference I can see is the skirt looks like it has a no symmetrical cut out to miss part of the crank? Valve cutouts look the same from the pics. Which way round were they before?
Rob.
Ahhhh, that makes more sense! I would go with arrow to front of car by default but have a look to see if the skirts are cut out to avoid a crank counter weight. I can't see any other differences. However the piston pin offset might not be equal, the rod end could be closer to the intake valve or exhaust valve if the offset is not equal.
Rob,
Yes I do dude, its been tucked up in the garage for 5 years now whilst I mess about with other things I started working on it again a few weeks ago so a resurrection might be on the cards. I'm glad you still have yours mate! how come the engine strip down?
Or good glad you didn't sell it. Be good to see it. Took it on a track day at knockhill and suffered from oil surge with having no baffles in sump. Took out the crank and no1 rod (heat damage) manage to drive the 3hr drive home no problem.
I would say the Arrow points to the thrust side of the bore
Standing at the front of the engine the thrust side is on the left.
This is proberbly because the gudgeon pin is offset on a 4x4 piston to stop piston slap when cold.
Cheers tim
Awesome mate, bet yours was a bit of a handful at a track day! Bit of a weapon before the problem though!
