Play in diff
Old Nov 12, 2015 | 07:02 PM
haz87's Avatar
haz87
Default Play in diff
Box is out and before i go to rebuild it, I just wondered if this was normal.
The "inner" part of the diff has movement, only a mm id say but i can move it about with my finger (if i put it in the splined inner part where the cv joints would lock in).
Is this normal or is it fucked?
Old Mar 11, 2023 | 12:18 PM
Beardy15's Avatar
Beardy15
Default Play in Diff
Hia, did you ever get to the bottom of this, I've stripped my box and founc the same, I thought I had an issue with the diff bearings as the drive shafts keep leaking oil after changing the seals several times. The play in my diff is more 2-3mm....
MAD YUM
215
May 5, 2019 12:56 PM
Sonic Boom
Dec 20, 2010 12:33 PM
ybturbo
May 7, 2010 03:02 PM
PGT
Feb 11, 2008 12:56 PM
Mike Rainbird
76
Sep 13, 2007 06:48 PM
