Focus mk1.5 Impact sensor
Old Nov 10, 2015 | 10:33 PM
MattSPL's Avatar
MattSPL
Default Focus mk1.5 Impact sensor
Can anybody help me out with the location of the impact sensor in the mk1.5 focus.
My airbag light is on and giving a code of 42 which is front impact sensor mounting fault.
I thought the sensor was below the front badge/lock, but no sign of it.
Thanks
Matt
Old Nov 10, 2015 | 11:04 PM
H3lsing's Avatar
H3lsing
ffoc.co.uk
This might be it.
Originally Posted by http://www.talkford.com/community/topic/159590-focus-front-crash-sensor/
As far as i am aware it is under the front slam panel, under the plastic trim. I have this job to do also on a 2003 mk1.5 focus. Again i haven't got round to it yet. Did you manage to gain any more information?
Thanks
Paul
Hi Paul,
Bit late to answer I think... But Yes, I found the sensor and replaced it. All fine now, no blinking lights.
It's indeed at the underside of the front slam-panel. Only 1 bolt holding it in place and I managed to get it out without removing the radiator or anything else!
If you still have to do this: good luck, it only a couple of minutes. Oh, I disconnected the battery and waited som 15 minutes before I started.
Regards,
Old Nov 11, 2015 | 09:46 AM
MattSPL's Avatar
MattSPL
Originally Posted by H3lsing
This might be it.
Thanks for the reply, I will have another look today. I couldn't see anything or any wiring there though.
Matt
Old Nov 11, 2015 | 11:09 AM
DangerousBryan's Avatar
DangerousBryan
You have to drop the radiator to get at it easily.it is on the bottom of the slam panel.
Old Nov 11, 2015 | 05:10 PM
MattSPL's Avatar
MattSPL
Ok thanks, I'll have a good look for it.
4x4RSMike
13
Dec 3, 2015 05:43 PM
morg65
Escort Range
Nov 13, 2015 02:09 PM
bodace5
16
Nov 10, 2015 05:24 PM
jdm
Nov 7, 2015 05:15 PM
jdm
Ford Fiesta
Nov 7, 2015 04:37 PM
