st170 headlamps
2 bolts/screws hold the lights in at the top. You have to remove the grill first which is also held in with 2 bolts/screws. Then if you look underneath the car where the sides of the bumpers are there are 2 bolts/screws one each side. Easy to remove.
Andypandy260
Sep 23, 2015 10:28 PM
