E38 brembo calipers! cosworth conversion help!
Old Oct 3, 2015 | 05:57 PM
wheelwizardrefurbs's Avatar
wheelwizardrefurbs
Default E38 brembo calipers! cosworth conversion help!
hi folks ive just bought some bmw E38 brembo calipers now the bloke said they are to suit 316mm discs but ive seen a load of people use the focus rs mk1 324mm discs is this true? its just the 316mm discs confusing me a bit. thanks everyone.
Old Oct 3, 2015 | 07:34 PM
costina's Avatar
costina
Live long and prosper!!
Sounds like a typical caprisport fuck up to me.
usually 324 focus rs discs. But they dont fit a 4x4 due to the offset.
Old Oct 3, 2015 | 07:37 PM
wheelwizardrefurbs
fuck up? how do you mean? mine is 2wd cheers
Old Oct 3, 2015 | 07:40 PM
wheelwizardrefurbs
will the focus 324mm fit the calipers i have?
Old Oct 3, 2015 | 07:48 PM
costina's Avatar
costina
ok the only way to tell is remove your caliper and disc bolt up the caliper and bracket measure from centre of hub to the outside edge of pad x 2 that will give you disc size.
I have had problems with caprisport and there crap disc conversions before.
Be aware some 17" wheels will not fit over calipers.
Hope that helps.
Paul
Old Oct 3, 2015 | 07:53 PM
wheelwizardrefurbs
i bought the calipers 2nd hand mate not off caprisport i just needed to know if the mk1 focus rs 324mm disc would be ok also im still yet to buy brackets, cheers mate
Old Oct 3, 2015 | 08:32 PM
costina's Avatar
costina
ok well best of luck.
Old Oct 4, 2015 | 06:37 AM
ircossie76's Avatar
ircossie76
I've got the brembo conversion on my 2wd sapph and I'm using mk1 focus rs discs. They work really well.
Old Oct 4, 2015 | 07:44 AM
wheelwizardrefurbs
cheers ircossie good to hear that before i go buying the disca and adapters etc,
Old Oct 4, 2015 | 05:13 PM
Joe Grp4 Escort's Avatar
Joe Grp4 Escort
Can you measure brackets when they come and share the info? I would like to get a batch made up
r.bartholomew
Ford Focus Range
Nov 16, 2015 05:04 PM
Oranoco
12
Oct 2, 2015 02:18 PM
locum8
Oct 1, 2015 01:50 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Sep 28, 2015 10:05 AM
