Whats it worth?
Hi guys
What is a 2.0 Zetec Turbo worth?
ST170 Bottom End
1.8mm Ford Gasket
Blacktop Head with ST170 Valve springs
Stage 3 T3 Turbo on CVH Modded Manifold
1.8 Flywheel
Rover Turbo Inlet with Red Injectors
Alternator + Mount
Thermostat Housing
Modded Breathers etc
New Cambelt, Pump etc
Thanks
ST170 Bottom End
1.8mm Ford Gasket
1.8 Flywheel
Alternator + Mount
Thermostat Housing
Thanks
