cosworth no pulse from injectors?
Old Aug 20, 2015 | 05:09 PM
wheelwizardrefurbs's Avatar
wheelwizardrefurbs
Default cosworth no pulse from injectors?
hi folks does anyone know what would cause no pulse at the injectors on my cossie? ive got fuel up to the rail ive got a good spark ive got all the wiring plugs on the correct way. i do have power at the injectors but will not pulse when cranking its got me baffled! any help on this will be greatley appreciated. thanks
Old Aug 20, 2015 | 06:57 PM
wheelwizardrefurbs
anybody have any ideas? cheers
Old Aug 20, 2015 | 08:08 PM
martysmartie's Avatar
martysmartie
Is power present at the injectors?
Martin
Old Aug 20, 2015 | 08:55 PM
james kiely's Avatar
james kiely
Have you got your earths all on with good contact
Old Aug 20, 2015 | 09:12 PM
wheelwizardrefurbs
hi lads yes i have power at injectors but they just wont pulse. i have X2 brown earths which are bolted to my inlet manifold how many more is there mate?
Old Aug 20, 2015 | 09:44 PM
martysmartie
Verify the the Phase sensor output is ok...
Martin
Old Aug 20, 2015 | 09:48 PM
wheelwizardrefurbs
im not sure mate i will be checking that tomorrow morning and il report back to you, thanks for the replies
Old Aug 20, 2015 | 10:06 PM
james kiely
2wd on the throttle bracket and 4wd on the back of the plenum ,two on the same connection .
Check if you had the wiring loom disconnected that you have the plugs on the right sensors as they can be switched easily enough
Old Aug 21, 2015 | 10:15 AM
wheelwizardrefurbs
I have put a new crank sensor on and its now pulsing but very weak it juat manages to light the bulb. still wont start. Fuel pump is working and got a spark. Cheers
Old Aug 21, 2015 | 01:31 PM
wheelwizardrefurbs
The car now tries to fire but will not start grrrr!
Old Aug 21, 2015 | 05:42 PM
wheelwizardrefurbs
the phase sensor wiring looks rough as f:@k also would this stop it from starting up and getting a very weak pulse? also when i first crank it over it will pulse bright then immediatley dim to the point where its barely visible.
Old Aug 21, 2015 | 06:01 PM
wheelwizardrefurbs
one more thing, when i use the test light on the X2 injector wires they are both constant live is this normal? ? with (ignition on)
Old Aug 21, 2015 | 07:15 PM
james kiely
Definitely stick a new phase sensor in it mate
Old Aug 21, 2015 | 07:39 PM
wheelwizardrefurbs
will do mate got one on order cheers for that .)
Old Aug 22, 2015 | 12:08 PM
wheelwizardrefurbs
so do you rekon that a knackered phase sensor would cause a weak pulse?
Old Aug 24, 2015 | 01:56 PM
wheelwizardrefurbs
New phase sensor fitted No change any other ideas?
Old Aug 24, 2015 | 03:41 PM
wheelwizardrefurbs
Ok its burst into life but only running on cylinders 1 and 3. The other two cylinders are sparking and pulsing but wont fire.
Old Aug 29, 2015 | 09:25 AM
martysmartie
Are all four lugs intact on the crank pulley, do you have fuel to those cylinders?
The injectors have a permanent supply, re your question, so this is correct.
Martin
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Russ Hill
Aug 31, 2015 06:44 PM
Aug 14, 2015 07:29 AM
Perfmr2
Aug 6, 2015 07:30 AM
