cosworth l8 ecu'd car problem
Old Jul 27, 2015 | 03:07 PM
steppy's Avatar
steppy
Default cosworth l8 ecu'd car problem
I am sorry my first post is a help needed, i have a problem with a L8 ecu car, it has an uneven idle it hunts a bit but not massively, when the car is revved the revs stay at around 3k, i have checked for vac leaks and none are evident, if I unplug the iscv the revs return to normal also if I remove the tps plug the car also returns to idle, the tps is a pf09 set to 0.35v throttle closed, from what's happening i am presuming the tps is faulty, it has a new ect sensor, act sensor, 3 bar map sensor, phase sensor. I have also given the iscv a clean just in case
I am ready to pull my hair out over this car
Old Jul 27, 2015 | 04:14 PM
oldford's Avatar
oldford
Tps is set a little bit too high for throttle closed.
It needs to be less than 0.30 Volt. Ideally set it around 0.17 volt.
Old Jul 27, 2015 | 05:06 PM
steppy's Avatar
steppy
Cheers fella, I've just been out and set it to 0.17 took it for a drive to warm it up and unfortunately it's the same
Old Jul 27, 2015 | 05:10 PM
botters's Avatar
botters
competant bodger
does the car have an l8 loom to go with the ecu or is it on the l6 or l1 loom if so the outer tps wires may need swapping around
Old Jul 27, 2015 | 05:15 PM
steppy's Avatar
steppy
It's a 2wd loom and I have already swapped the outers, i should of really said that, cheers for the thought though
JoeyBoyden
Jan 4, 2024 02:36 PM
big_Rad
Sep 15, 2017 09:36 AM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
